Old 07-02-2010, 02:23 AM   #11
Green7mgte
Supra Forum Moderator
The cat and cat back are the same on turbo and non turbo
yea i didn't know for sure weather or not there were any size differences. never worked on an NA.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 07-02-2010, 05:27 PM   #12
The cat's are different. The GTE's is large and flows a greater volume. You should be able to bolt it up just fine though, the flanges are the same size IIRC, just might have a little trouble lining up the exhaust gasket so there aren't any leaks.
Old 07-02-2010, 07:03 PM   #13
Green7mgte
well with the larger cat on an NA.. would your emissions test suffer?
Supra FAQ
Supra MKIII FAQ
Old 07-03-2010, 08:06 AM   #14
Not at all. They're built the same way. The GTE's is just larger and as such has more catalyzing surface area capable of processing more gas.... could *possibly* make for even better emission scores. The only real reason they didn't use that one on the N/A's too is that the materials inside are so costly.. so, you go with the smallest you can get away with.
exhaust question (not in exhaust faq) sd88supra MKIII Supra 21 11-28-2006 10:52 PM
Turbo lag question. rnoswal MKIII Supra 6 02-12-2006 05:42 AM
