#1 |
New to the forums and i have a few questions, i would like just answers and no hmmming and hawwing. i am getting a 1989 toyota supra turbo I would like it to be about 600-700 HP now i know most of the stuff i want to get me to that amount of power but what kind of engin backup work do i have to do so my engin dont blow. Im planning on getting an HKS metal HG with more depth to it to drop my compression and im goign to do all the suspension and ball joints and that lovley stuff. what else do i need? Thanx.
#2 |
7M POWAH! ;)
i would suggest you get forged rods & pistons with all arp hardware... it's gonna get you reliability
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
#3 |
cool how many G's you think those would run me at? is there anything else?
#4 |
7M POWAH! ;)
not sure of the pricing over there for those items... but here for a set of rods and pistons would cost bout $2500ish nz dollars
definitely hks gasket with arp head studs walbro fuel pump (or even larger) fuel pressure regulator injectors 6-700hp i would honestly suggest an aftermarket ecu for efficient tuning arp main and rod bolts can't think of anything else
#5 |
i have looked in allot of places and i cant realy find an ECU i really like other than STAND ALONE but i need to think if that will be worth the doe$$$ cuz its allot of money for a fuel managment system.
#6 |
SP58GT
i also recommending upgrading valvetrain if youre gonna make that amount of power, ull need to think about the valves, the retainers, the springs, also think about fuel management because running lean...is just not cool, ull probably need new injectors, fuel pump....hhaha u know wut i just realized i said almost the same exact thing as suprra girl...oh well...its the right thing to do, as for the ecu... i think its harder to make that amount of power off a piggyback..though possible its not easy...a standalone is a lot more efficient, but yea it will cost some hard earned cash but i think its the best way to go because there are more choices and applications if you go standalone, piggy back is also good but when make serious power such as 600-700hp...i would recommend getting a standalone
#7 | |
I've only built larger motors(350's, actually). And as I prefer higher revs a really tough crank is required. What kind of crank does the 3 litre motor come with stock? And where could I find a 4340 or 4130(or whatever) steel crank? |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Headlights only work on High Beam - is it a fuse? | t4yl0r10 | Non-Generation Specific Questions | 8 | 01-18-2008 03:56 PM |
| N20 and HeAd WoRk | Supra_87_mk3 | Non-Generation Specific Questions | 4 | 05-25-2007 03:09 PM |
| Dash lights Don't Work | supra67 | Non-Generation Specific Questions | 4 | 09-05-2006 04:58 AM |
| Dash lights Don't Work!! | supra67 | MKIII Supra | 0 | 08-10-2006 01:11 AM |
| will this work | jride1999 | MKIII Supra | 19 | 12-11-2005 04:47 AM |
