Old 07-05-2010, 07:24 AM   #1
batmmannn
batmmannn's Avatar
Default Oil loss in my red 7m na
OK Guys I have no oil leaks in the front or top of the motor, no dripping, no evidence of leaks in those areas. I have to assume that I am blowing out of the rear main now. Or possibly the drain plug will look at it tomorrow.
Found my car with over 3 quarts low, after noticing the oil pressure guage was dropping to nothing. Only get some blue smoke after back pressure builds down a long hill and then a nice puff barely visible at the end of the hill on take off.
That would be kind of expensive as I am looking at 4 quarts loss at about 500 miles of driving. This stuff aint cheap.
Overheated today using the AC and not knowing I was low on oil and not fully burping the car after the radiator hose replacement and AC repair.
Looks like I will be watching the oil closely now till I decide where I am losing it. I suspect I will have to drop the trans and replace the main seal.
Get a new drain plug and gasket. Might as well throw a new clutch plate in there as well when I do it.
Can the trans be dropped easily or is it better just to pull the motor with trans attached?
AC IS WORKING AWESOME! My first AC Repair and recharge and I guess I got it right. Can the motor be pulled without opening the compressor lines? I would think it could but imagine it would be tight.
Oil pressure went back above 20 at 2,000 rmp after refill.
Comments would be appreciated. Thanks
Old 07-05-2010, 01:02 PM   #2
Oil out the exhaust = internal leak, not external... Bad rings, turbo seals, BHG, cracked head, valve stem seals, etc.
Old 07-05-2010, 01:51 PM   #3
burping your rad is a great idea don't get me wrong.. but its not going to sufficiently ruin anything in a matter of moments if there is an air bubble or two trapped in there.. and they will eventually make their way out anyhow.
Old 07-05-2010, 03:20 PM   #4
wstanek
wstanek's Avatar
im gunna have to go with the rings valve steam seals or somthing of that nature.... didnt u just rebuild that motor? mabey im thinking of somone else... u posted a video on youtube right?????
1987 N/A 7MGE manual transmission slight rod knock never driven it yet... legally~
Old 07-05-2010, 04:12 PM   #5
batmmannn
batmmannn's Avatar
Default No rebuild
No I did the valve covers, front crank seal, timing belt. No internal rebuild. I am not blowing blue smoke except after a long coast down a 1 mile hill with it in gear and only for an instant after during take off. I don't have a Turbo or a blown head gasket that test was already done. Drove it to town last night after burping it with the AC on high about 16 miles and it did not overheat after burping. Losing oil from the rear crank seal I think. Probably do need new valve seals though. No pools or drips of oil on my driveway but the rear trans has oil all over it. The plugs would show oil fouling if I was burning a lot of oil correct?
Old 07-05-2010, 04:41 PM   #6
wstanek
wstanek's Avatar
yeah true if it was burnin oil you would have a lot of shit on the plugs. how much dose it burn again. im in alganquin park on holidays =D
Brake loss at high speeds 86.5 7MGE MKIII Supra 15 10-28-2009 04:28 AM
Interesting power loss problem! stssa MKIII Supra 4 01-13-2009 04:54 PM
Instant Power Loss kylejoseph Non-Generation Specific Questions 1 05-28-2008 12:41 PM
Little Coolant Loss justin1642 MKIII Supra 15 08-06-2007 12:41 PM
Massive power loss 808Supra MKIII Supra 3 05-24-2006 02:58 AM
