Old 07-05-2010, 11:27 PM   #1
Get a JDM ECU.
Old 07-06-2010, 12:03 AM   #2
Conga1991
Conga1991 is on a distinguished road
for what? not using the egr
Conga1991 is offline   Reply With Quote
Old 07-06-2010, 12:26 AM   #3
Yup. Or add a fuel controller, run open loop full time and tune the engine to run a little richer at cruise.
Old 07-06-2010, 02:10 AM   #4
Conga1991
what you said was a bunch of giberish. also on the ecu I have it has a plug coming out, what plugs into it? I couldnt find a port for it to go into. (I have a 88 NA body and the Motor is a 87 7mgte same as the M/T ECU)
Old 07-06-2010, 02:16 AM   #5
batmmannn
batmmannn's Avatar
Default Gibberish?
What Cre says is never Gibberish, but I understand how you feel. I have to do research sometimes to keep up with Cre. You have to read what he says and then race to catch up by reading info about what he is trying to tell you. Cre has told me things that overload my capacity of knowledge and then I do keyword searches and research terms and functions to understand what he is telling me. You have to do some of the work yourself to learn the abbreviations and the systems he is talking about. Upload a pic of the areas you have questions about so we can see what you are talking about. This is the easiest way.
Old 07-06-2010, 03:33 AM   #6
The pigtail coming out of the pre89 GTE TCCS (ECU) is for the HAC sensor (High Altitude Compensation)... it's essentially a clumsy MAP (Manifold Absolute Pressure) sensor which is used to help adjust fueling when there are significant changes in air pressure. You can run without one if you live at sealevel... if you live at a higher altitude you'll be fine too as long as your dialy driving doesn't involve a lot of changes in altitude, but you will be running richer than you need to and your gas mileage will suffer a bit.
I don't to gibberish....
....except for when I do.
Old 07-06-2010, 03:58 PM   #7
Green7mgte
Supra Forum Moderator
there wasn't even any abbreviations in that post he was talking about.. just didn't understand what open loop meant.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
7mgte swap vs 1jz swap Supra Saiyan MKIII Supra 15 04-24-2012 02:58 AM
2JZ GTE Swap questions geli MKIV Supra 4 09-09-2009 01:43 AM
7mgte Swap SilverBullet05 MKIII Supra 3 07-17-2008 12:18 AM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
