Old 07-06-2010, 03:10 AM   #1
Jay633
Jay633 is on a distinguished road
Default Timing?
thanks to you guys i replaced the o-ring on the distributor, i put it back and my car wouldnt start, so i set it to the 1st cylinder, and now it start but it doesnt feel right, at idle the rpm needles moves alot , and when im around 2k rpm the car shakes.
Jay633 is offline   Reply With Quote
Old 07-06-2010, 03:15 AM   #2
907mge
907mge's Avatar
Did you set the timing?
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=20
Old 07-06-2010, 03:35 AM   #3
You need to set BOTH mechanical timing and spark advance:
http://www.toyota-supra.info/forums/...-e-timing.html
harmonic balancer came off crank shaft help? wishiknewmore MKIII Supra 3 04-15-2011 11:04 AM
Timing Knock or tap batmmannn MKIII Supra 5 06-02-2010 03:20 AM
Exhaust vs Timing, something else? Krem MKIII Supra 9 03-18-2010 02:39 AM
timing problem with knock robertsws MKIII Supra 1 09-04-2009 03:40 PM
Timing question Kevin MKIII Supra 3 07-10-2009 07:52 PM
