Old 07-06-2010, 11:26 PM   #1
spins2
spins2 is on a distinguished road
Default sometimes dont start... help please?
well this just started happening. sometimes wen i drive it for a while or do some strong pulls on her wen i shut it off it wont start right away. its like it has to cool down. but my temp gauge is good. im leaning to a bad feel pump on its way to being done??? any suggestions?
spins2 is offline   Reply With Quote
Old 09-28-2010, 07:10 AM   #2
supragreen
supragreen is on a distinguished road
Smile
change the fuel pump
supragreen is offline   Reply With Quote
Old 10-08-2010, 05:40 PM   #3
Metaphysico
Metaphysico is on a distinguished road
Cold start injector switch problem maybe, could be thinking the car is cold and adding too much fuel.
Metaphysico is offline   Reply With Quote
Old 10-10-2010, 06:56 PM   #4
The cold start injector only has power when the engine is cranking.
Old 10-11-2010, 10:03 PM   #5
supralou42
supralou42 is on a distinguished road
Default won't start
If it does not want to turn over (crank) check the ignition start switch.
run a wire from the starter solonoid thin wire, blue in color. turn on the ignition switch. touch the wire from the starter to the pos terminal of the batt. if engine cranks and starts, you have a bad ign switch.
supralou42 is offline   Reply With Quote
Old 10-30-2010, 07:36 PM   #6
Metaphysico
I was thinking he meant it took a long time of cranking to start not that it would not crank. The starter signal wire is not very good so if it wont crank you may want to look into the starter rewire. You use a ford starter relay to supply power to the starter. Otherwise if it cranks for extended periods but wont start check into the cold start switch.
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Stalling at start up Green7mgte MKIII Supra 4 12-15-2009 06:31 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
