Old 07-07-2010, 03:55 PM   #1
bobo4life
bobo4life is on a distinguished road
Default 1991 7MGTE to 1987 7MGTE
I have a problem. I work at a shop and we have an interesting combination of elements here. I have a 1991 Supra Turbo with an engine MT and ENGINE wire harness that came out of a 1987. THe owner gave up on trying to figure this out, and now its in our lap. I'm wondering if anyone can give me some advice. I'm seeing from difference in the wiring diagrams that there are major differences all around as far as routing and pin configurations. First of all, does anyone know if it will work out? Secondly does anyone know if the ECU is ok to use- mine has the part# 89661-14260 (which from other forums shows to be a 1989 part number which came with the 1991 car). What I need to do is make it run. There are a couple connectors under the dash for the ECU harness and engine harness that are different (some wires at different pins, some not even there on one side or too many on the other). I have a set of connectors to start switching stuff over, but there's missing wires or extra wires that between both diagrams show them going different ways. I'm really frustrated at this thing, and don't even know if it will work. Anything you can advise would be appreciated.
bobo4life is offline   Reply With Quote
Old 07-07-2010, 04:59 PM   #2
Supra Saiyan
Supra Saiyan's Avatar
Supra Saiyan is on a distinguished road
Just tossing this out there.. I have only a slight knowledge of the actual mechanics of cars. Is it possible that the car got its wire harness from japan and its just different than a US one? Do you know if the 1991 engine was actually a swap from the original? those would be my 2 guesses at it. I would have thought they where interchangeable.. Is this 87 7MGTE from japan?
Supra Saiyan is offline   Reply With Quote
Old 07-07-2010, 06:46 PM   #3
bobo4life
Default Not too sure, but almost positive....
The engine that blew came with the car and it was a US car, and the engine that went in was a scrapped engine from a boneyard which came out of an 87 US car (as far as the owner knows). I'm looking around for wire harnesses and possibly an ECU, but I don't want to buy them without needing to.
Old 07-07-2010, 06:53 PM   #4
btwilson86
Super Moderator
btwilson86's Avatar
Did they swap anything else over from the 87 Supra? Such as the fuel injector resistor packs on the firewall? I'm assuming that since the 87 harness is still connected that they kept the 87 fuel injectors and fuel rail...
If I was in your situation, I'd get the fuel injectors and wire harness from a 89+ turbo supra. That way the factory gauges will operate properly and it should just be plug and play. If a wire harness is hard to find, you can get a 87 ECU, 87-88 Gauge cluster + dash harness, the resistor packs for the fuel injectors, and maybe some other odds and ends to get it running right.
I'm sure it's possible to rewire the connectors on the wiring harness to make it connect to the ECU properly, but you will still need to address the fuel injectors. pre89 7MGTE's use low impedance injectors, whereas 89+ used high impedance injectors (I think that's right, might be the other way around though; trying to recall from memory).
Anyway, help this gets you pointed in the right direction.
Old 07-07-2010, 06:59 PM   #5
batmmannn
batmmannn's Avatar
Default Unnngh
Sounds like a real headache, Glad I'm not attempting it. By the time I had it figured out and picked enough brains I would have wasted more time than the car was worth.... But that's just me.
Old 07-08-2010, 02:55 AM   #6
All years 7M-GTE used low impedance injectors. Only 7M-GE's saw that change.
Old 08-03-2010, 02:32 AM   #7
blake
blake is on a distinguished road
Default same project
i have a 91 supra and it is a na, and im at the same problem, well im building it. i bought an 88 supra and i found out the harness is different and all. if u can what u figure out post so i can go over the info so i can then save time myself.. i know it is a pain in the rear...
blake is offline   Reply With Quote
Tags
1987, 1991, conversion, ecu, wiring
