OK...I give up...
Been looking for an intake kit for my 7MGE...
If anyone has a link, I would love to have it...thanks! |
There is no production intake kit for the GE. Custom is the only option. This has been discussed to disgusting degrees on here in the past, I'm surprised you can't find any info. Try searching phrases like "cold air intake" and "civic intake" and "helmholtz".....
Thanks...I did the intake searches, but most were dealing with the Turbo, or some other variation. OK, on to the next thing...thanks again! :nuts:
really?? if you just need a cold air intake... check this guy out:
http://rabidchimp.com/mkii-supra-82-...ntake-kit.html for this custom piece it requires you make a hole right infront of where the afm used to be, and then you just connect it to the afm.if your piping is busted, there is pretty much no place that has the same piping your gona have to find a smashed supra OR try a google search you'll be supraised what comes up |
idk about that noise I coulnt make heads or tales form the pictures..
as for the Original question just do it the simple rout. buy an air intake with about a foot or so of piping and make a box under your headlamp. not to mention most of the stuff on that website is way overpriced... and half of the items don't have pictures. |
