Old 07-16-2010, 12:39 AM   #1
Supra_King
Supra_King's Avatar
Supra_King is on a distinguished road
Unhappy 7mgte has no power won't go past 2000rpms HELO
Hey everyone i have a 1988 toyota supra 7mgte 5 speed, in nutral or holding the clutch the car will rev as far as it can but in first gear it wont go past 2000rpms whats wrong with it? if anyone can help thank you so much
Supra_King is offline   Reply With Quote
Old 07-16-2010, 01:20 PM   #2
hmmm, without more info im going to say fuel cut off or, vacuum leak.
the turbo charger system is obviously pressurized and over time leaks may develop.
so what happens @ 2krpm? does it have 0 power or what?? just that:
"in first gear it wont go past 2000rpms whats wrong with it?"
not the most descriptive...
Old 07-16-2010, 02:21 PM   #3
Supra_King
Supra_King's Avatar
at 2k it will just stay there it wont go more then 2k rpms and the car seems to sound like it back fires
Old 07-16-2010, 05:46 PM   #4
Did you do any work on the car before this happened? Did this suddenly occur, or has it been slowly getting to this point? How long have you owned the Supra? What kind of mods do you have on it?
Old 07-16-2010, 08:52 PM   #5
Supra_King
Supra_King's Avatar
iv owend the car for about 2 weeks,the person i bought it from said they did the timing belt and head gasket,i did the coil pack and valve cover gasket,only mods are a air filter and exhaust,
the car has been like that since i bought it
Old 07-17-2010, 01:00 AM   #6
if a timing belt was done, i would assume something is wrong with the timing.
get a timing light from a friend or buy one and check the timing.
either way you should check over everything about the car.
you may find out more than you could have imagined.
Old 07-17-2010, 02:13 AM   #7
Supra_King
Supra_King's Avatar
the timing is fine iv check it already
Old 07-17-2010, 02:47 AM   #8
when in doubt...
CHECK FOR ERROR CODES!
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=23
follow the instructions.
Old 07-17-2010, 02:55 AM   #9
Supra_King
Supra_King's Avatar
when in doubt...
Problem is i need to replace the bulb but thos instructions help thanks i should be doing this tomrrow thanks
Old 07-17-2010, 03:06 AM   #10
lol at least bulbs are cheap. and its about time, because you should always have operational engine lights
jdm 7mgte more power than usdm gte????????? jdmmilhouse MKIII Supra 21 07-13-2010 03:16 AM
no spark chrism8799 MKII Supra 6 12-08-2008 12:38 AM
Ghetto is a good seller ARZ Buyer/Seller ratings 0 11-15-2006 11:58 PM
