Hey everyone i have a 1988 toyota supra 7mgte 5 speed, in nutral or holding the clutch the car will rev as far as it can but in first gear it wont go past 2000rpms whats wrong with it? if anyone can help thank you so much
hmmm, without more info im going to say fuel cut off or, vacuum leak.
the turbo charger system is obviously pressurized and over time leaks may develop. so what happens @ 2krpm? does it have 0 power or what?? just that: "in first gear it wont go past 2000rpms whats wrong with it?" not the most descriptive...
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
at 2k it will just stay there it wont go more then 2k rpms and the car seems to sound like it back fires
Did you do any work on the car before this happened? Did this suddenly occur, or has it been slowly getting to this point? How long have you owned the Supra? What kind of mods do you have on it?
#5 | |
![]() Quote:
iv owend the car for about 2 weeks,the person i bought it from said they did the timing belt and head gasket,i did the coil pack and valve cover gasket,only mods are a air filter and exhaust, the car has been like that since i bought it |
#6 |
if a timing belt was done, i would assume something is wrong with the timing.
get a timing light from a friend or buy one and check the timing. either way you should check over everything about the car. you may find out more than you could have imagined.
jdm 7mgte more power than usdm gte????????? | jdmmilhouse | MKIII Supra | 21 | 07-13-2010 03:16 AM |
no spark | chrism8799 | MKII Supra | 6 | 12-08-2008 12:38 AM |
Ghetto is a good seller | ARZ | Buyer/Seller ratings | 0 | 11-15-2006 11:58 PM |
