Hello folks! I've got an '89 7M-GTE that won't run. Long story short, I just fixed a code 52, buttoned everything back up, and it won't fire. It's setting a code 12. It has been hesitating randomly under load for a while, getting progressively worse, but it never set a code 12 until now. Only the number 3 coil pack is getting spark, and I switched the igniter and got the same result. I checked the engine ground and it's tight and intact. I checked the wiring to the CPS and it seems fine. I'm thinking the CPS took a crap. I searched the forums, but couldn't find much on code 12 other than TSRM links. What I'm wondering is, has anyone else had this problem or am I barking up the wrong tree?
![]() Thank you in advance, ---Nick |
Bone Stock w Upgrades ;-)
Check the CPS side of the harness with an ohm meter. 140 to 180 Ohms with the probe touching the lower right first (G-, or ground), then touch the other probe to the other 3 in turn. should read 140 to 180 Ohms each time. A Supra repair manual is a good invesment. Make sure the engine wiring harness
ground wire bundle is tight. Its located where the EGR VSV valve is mounted low on the intake manifold. I had some strange engine problems one time because the bolt was only hand tight (intermittent ground). Last edited by Bru; 07-18-2010 at 05:10 AM. |
Tags |
7mgte, code 12, cps, no start, wiring |
rebuilt hard to crank (high engine resistance); need advice | cbrewster | MKIII Supra | 4 | 09-28-2009 04:52 PM |
problem seperating engine from manual tranny | Gengus | MKIII Supra | 7 | 01-29-2008 12:10 AM |
my 1995 supra engine wont fire | gkhawk | Non-Generation Specific Questions | 6 | 08-25-2006 09:58 PM |
Keeping Engine Cool | mrnickleye | Supra FAQ | 0 | 06-04-2005 10:02 PM |
