Old 09-04-2010, 04:46 PM   #1
Life is Supra
Life is Supra is on a distinguished road
Default Crankshaft pulley?!?
Hi people,I have a BIG problem with I think crankshaft pulley...I check codes and it showes me code 12.The main nut on crankshaft pulley was replaced by previous owner(he probably hit it somehow and twist it a little bit),so when car runs she is woblling(my english is a bit rough-sorry).Now to see what is the main problem I have to desamble the engine but my question is this-do I have to rip apart whole engine to get to crancshaft and other stuf or can I go easy way(I know there's no easy way to do it)and desamle just a bottom of the engine to see is it a problem in the pulley,or maybe just a center nut,or maybe a crancshaft?
Life is Supra is offline   Reply With Quote
Old 09-04-2010, 08:33 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Sorry! but it’s more than likely the shaft end is damaged where the pulley is attached. What normally happens is the pulley (which is fair chunk of metal) wobbles about on the end of the shaft and chews up the key-way and shaft. If the crank needs to be removed than the engine will need to be pulled to gain access to the sump. If you could post a photo of the shaft end, I`m sure someone could advise.
1980 Supra Crank Pulley (Harmonic Balancer) steve6163 Non-Generation Specific Questions 7 06-18-2010 01:47 AM
Crank Pulley btwilson86 MKIII Supra 10 05-22-2010 03:30 AM
Water pump pulley bryanf89 MKIII Supra 11 01-25-2010 04:21 PM
Power Steering Pump Pulley trevor217 MKIII Supra 4 05-17-2009 08:28 PM
problems with my power steering pump pulley... maniakwithpistol MKIII Supra 1 12-05-2008 09:16 PM
