-   -   1988 Automatic Shifter (http://www.toyota-supra.info/forums/mkiii-supra/17446-1988-automatic-shifter.html)
Rocky322 07-20-2010 11:52 PM
I have a 1988 Toyota Supra Automatic.. My shifter moves around like crazy. Does anyone know the problem or how to fix?
cre 07-21-2010 03:08 AM
Please make sure you post in the correct section. The section you posted in is for posting problems with the site or suggestions and questions relating to it.
Thread moved.
mirage83 07-21-2010 11:10 PM
Shifter bushings are worn out. There's two (one for each end of the bolt the shifter rides on) and available from Toyota for a couple bucks. Easy fix.
suprajim 08-02-2010 04:15 AM
Check out this link: http://www.cygnusx1.net/Supra/TechTi..._bushings.aspx
I had to do this myself and it was super easy.
