Old 07-22-2010, 07:48 PM   #1
spins2
spins2 is on a distinguished road
Default will this prevent fuel cut?
will the lexus ls400 maf meter allow to push more boost. stock 12lbs fuel cuts. all i have is fmic. i heard if i got this it allowes to push more but i also hear i need injectors to. can anyone help me?
spins2 is offline   Reply With Quote
Old 07-23-2010, 12:05 AM   #2
i know alot of people take them out of lexus but im not sure on what models.
your on the right track.
if you add more fuel. (pressure, or injector size)
you need to add just as much air.
have you looked into an aftermarket inter cooler, cooler, air= more air
also when using this site you SHOULD. fill out your profile info about your car, AND put your car/year/mods on car. its alot easier to help if people know wtf your driving.
Old 07-23-2010, 01:19 AM   #3
The 400 series Lexus (SC, LS, etc) use an AFM which allows approximately 25% more UNMETERED through. You MUST add approximately 25% more fuel as a result (~550cc injectors are just about right). This does allow you to boost more as the ECU thinks the engine is getting 25% less air than it really is.
DO NOT run a Lex AFM if you do not have upgraded injectors!
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
fuel problem?.... i think supraluver4life MKIII Supra 0 03-22-2010 08:20 PM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel injectors Biku Off Topic Forum 7 07-23-2005 04:36 AM
