Old 07-22-2010, 04:50 AM   #1
Supra Saiyan
Supra Saiyan's Avatar
Exclamation Exhaust leak at the E. Manifold
I have a leak of exhaust at the manifold where it connects to the pipe below. It's a small leak. Do I just need a new gasket there or seal or something. I imagine I just need a new seal there but am unsure of the name of it's name.
How much for one of these (Seals), and can I install myself without any lifting the car or blow torch.?
Car is NA fully stock..
Old 07-22-2010, 01:03 PM   #2
i suggest exhaust glue or a rtv that is good with heat.
if it did this in the first place its possible its not entirely flat.
Old 07-23-2010, 12:56 AM   #3
The collector has two O-ring gaskets; they're quite inexpensive (maybe $5ea). Sure you can do it yourself as long as you can get the bolts loose. After 2 decades they're usually absolute monsters but soaking them with PB Blaster a couple times and then letting it soak in for a night usually helps.
Look here:
http://www.cygnusx1.net/Supra/Librar...spx?F=1702&P=1
Old 07-23-2010, 03:23 AM   #4
Supra Saiyan
Lol, ya got them and tried to take them off already.. Quite funny it was.. Haha! I am headed down to soak them again... Ugh, hope I get them off soon. Don't want to pay anyone to do it.. Maybe I should rent a power tool.. Thanks for the info and the link.
Look here:
Old 07-23-2010, 03:30 AM   #5
i would suggest a electric impact to remove, i dont like using power tools to put nuts and blots on, it can go wrong fast.
Does the exhaust manifold need to come off to replace head gasket? BillW MKIII Supra 1 10-02-2009 12:19 AM
White smoke from exhaust manifold Rommy MKIII Supra 15 07-26-2009 06:32 PM
Non Turbo JZA80 Exhaust Manifold SupraJAZ MKIV Supra 3 04-19-2007 12:19 PM
