Old 07-24-2010, 01:37 AM   #1
wstanek
wstanek's Avatar
Post OK well here we go again =S
ok so here we go with another interesting excursion! i need to do rod bearings on my 87 N/A the thing is is that i don't reapeat don't want to pull the motor i was examining how i could do this but it seems i would have to lift the motor up fck.... ok well anny help is greatly appreciated =D
1987 N/A 7MGE manual transmission slight rod knock never driven it yet... legally~
Old 07-24-2010, 04:47 PM   #2
Pulling the engine on a N/A is easy, should only take you a couple of hours. Plus it will make the whole job much easier, as well as allow you to inspect all of the wiring and vacuum lines that you can't see with the engine in the car.
Old 07-24-2010, 05:44 PM   #3
Just swapping the poin pan and oil pump with the engine just lifted is a miserable hell and takes hours longer than it should. Besides, if you pull it you can replace all the oil seals and the mains as well and just be done with it all.
Old 07-24-2010, 06:31 PM   #4
wstanek
wstanek's Avatar
Default no cherry picker
there is only . Issue i dont have a cherry picker and might not be able to get . Plus
Old 07-24-2010, 07:07 PM   #5
You can't lift the engine high enough to get at everything you'll need to without a hoist... forget it.
Old 07-24-2010, 08:29 PM   #6
Busted Knuckles
Busted Knuckles's Avatar
They don't have tool rental places where you are? Before I purchased my picker, I rented from a place near where I work. They charged $35 a day, but were not open on Sun. I could pick it up on Sat. morning and return it Mon. morning for the one day rate. Timing it right, I pulled two engines and dropped one back in this way on a single weekend once (pulled bad motor, pulled donor motor, and dropped donor motor back in original car.)
Call around. I'll bet you can find one.
Old 07-24-2010, 09:53 PM   #7
wstanek
wstanek's Avatar
man i owe u big time never even thought about rental and yeah i could rent . Cuz my buddies dad work at one of the largest self owned rentals in north america derp! 0.o ok ill have to do it yay.
Old 07-28-2010, 11:39 PM   #8
wstanek
wstanek's Avatar
ok so ive decided to pull it just need to rent a engine hoist~
Old 07-28-2010, 11:45 PM   #9
hell since were on the subject of pulling engines. how hard is it for a turbo? Ive never done one before. can anyone point me in the direction of reading material? ive been wanting to for awhile now.
Old 07-28-2010, 11:50 PM   #10
wstanek
wstanek's Avatar
hahaha gotta do bearings on my ge but prolly the same just less space for removal
