Old 08-04-2010, 12:51 PM   #11
Travis89Turbo
Travis89Turbo's Avatar
Ya i understand that completly.... The noise stops in gear while stopped i beleive its due to the rpm bein lower as soon as i go above 1000 it starts.. torque conv. makes sense also cuz it sounds like the noise is rotating. like chunks of metal rolling around in a drum. im still gonna try cats. if it is the tranny ill run it till she breaks i plan on R154 swap as soon as i can find one someone will ship. the car actually shifts really well except on decel. it like it engages then disengages
Old 08-04-2010, 01:11 PM   #12
MA70-3.0GT
MA70-3.0GT's Avatar
Mmmm, that engage/disengage does point towards trans issues... but only on decel.... or perhaps it would "hunt" between gears at certain steady speeds sometimes & you just haven't experienced that yet...
Either way I think that if you're planning a manual swap, you have the best idea so far in getting your moneysworth out of the autobox while you accumulate the R154 bits, but maybe try checking &/or changing the trans fluid & filter (what does it look/smell like by the way?) and have a look over the adjustment of the cables (kickdown & shifter) to see if there's anything awry there first...
P.S. Actually, I'm sure there was some kind of diag you could do on the gearbox in TSRM but I can't find it, usually if there's an electronic fault though the O/D light flashes...
EDIT-: Ah, found it!!! http://www.cygnusx1.net/Supra/Librar...aspx?S=AT&P=14
Old 08-24-2010, 12:55 AM   #13
Travis89Turbo
So it don't look like we'll get to find out what the noise was caused from.... let the wife drive it to work and I have now become a victim of BHG. I ain't messin around with the 7mgte anymore although I know it can be a bad mother hugger... I have built two of them but I need a more reliable daily driver for more then 100k. Without needing to rebuild. so my 1jzgte front clip with 86000km or around 52k miles on it will be here on weds.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Weird noise, sounds like a fan happysupraowner:) MKIII Supra 12 04-24-2009 01:35 AM
Weird noise from rear trevor510 MKIII Supra 2 02-23-2008 08:46 PM
Weird noise from MK IV 5-speed tranny!! Help! Bone_Stock_Supra MKIV Supra 9 01-16-2008 08:35 AM
HELP! My engine just started a weird noise... idoke MKIII Supra 12 10-05-2006 05:06 PM
weird slurping noise?!? Supro Non-Generation Specific Questions 1 09-22-2005 11:27 PM
