-   -   mkiii help (http://www.toyota-supra.info/forums/mkiii-supra/17539-mkiii-help.html)
mkiii- 08-04-2010 02:56 AM
mkiii help
hi i just bought a mkiii and it has bean smoking when i first start it and when i do a pull. i took off the piping to tho intake and there is a lot of oil in it i was wondering what is wrong
mkiii- 08-04-2010 03:31 AM
question
i have oil in my pipeing to my intake do u think its a blown turbo?
Green7mgte 08-04-2010 04:06 AM
no.. how much oil?
see http://www.toyota-supra.info/forums/...-oil-loss.html
cre 08-04-2010 05:52 AM
Thread moved to the correct section. Carry on. ;)
Green7mgte 08-04-2010 03:14 PM
so you have your engine smoking at astart up? low compression? is there a milky substance in on your oil dipstick? were about in the motor are you seeing the smoke.
valve stem seals smoke and usually present their problem at startup.
tips and walkthrough for valve stems..
worst case scenario tho
http://www.supras.com/06/techcenter/display.php?QID=5
mkiii- 08-05-2010 03:30 AM
the smoke is out the exhaust. the oil is in the piping all the way through the intercooler and probably in the intake and its a good amount of it in there. but it boost good but at a high rmp's wen i let off the gas i here a little grinding from the turbo. and there is no milky substance on the oil dipstick.
