Old 08-05-2010, 09:02 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
Lightbulb JE, CP, or wiesco pistons?? parts help
I have an 89 supra turbo a/t. Goin to be buildin up my 7mgte this winter and I'm starting to order parts its not my first supra build but I'm tryin to go over the top on this one. What is a better piston to run that I can make the most power on, trying to break 500 or as close as possible. But here's the kicker I want to make it pass emissions. By adding Y pipe with before the cat. To run straight pipe and running separate parameters on ecu to make it run clean enough to pass. Does anyone think this is possible? Also what cams and springs could I run that will hold the power but still keep me street legal?? if possible I will be running eagle h beam rods to push the piston. Also will bein goin to R154.
Old 08-05-2010, 10:52 PM   #2
Sonyps307
I got a set of Wiesco pistons they only sell the turbo pistons with 9:1 When I think je and cp sell 8.4:1 if u got everything forged i think 9:1 would be better On get more power on less boost
Old 08-05-2010, 11:06 PM   #3
Sonyps307
Also brain crower make a set of stage 2 cams that is good for street/track and they also make springs and valves to
87 MkIII vs 89MkIII -- parts interchange willblock MKIII Supra 5 07-24-2016 06:27 PM
Collection of Sources for Parts for the MK3 tangsuto MKIII Supra 0 08-17-2009 04:21 AM
Wiseco pistons... (interesting stuff) Suprapowaz! MKIII Supra 2 04-10-2006 04:07 PM
