#11 |
Supra Forum Moderator
its a 20 year old car.. and people drive the crap out of them.. do yourself a favor and replace all the coolant hoses at the same time.. not one at a time when they blow like i did...
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#12 |
ok so now i come to find out i need a radiator. gonna have to wait till next month on that one.
but i want to fix the egr problem.... by deleting it. my only question is i read people thinking they would have to take the head off in order to intall the plates and my leak is on the block on the intake side?? can i just block the intake side of the block and the intake mainfold. is there anything on the back of the head that i have to block? Last edited by vbryanv; 08-18-2010 at 04:34 AM. Reason: add comment |
#13 |
i wouldnt delete the egr.. it does your car good. like milk for the exhaust system. makes your body cold and grow up strong..
#14 |
u may have checked already but check the thermostat. If its stuck closed it will cause an overheating problem, then that leads to leaks and so on. Wrong temp thermostat can do the same thing if its really hot where you are.also i would suggest a system flush in case there are any blockages. As the coolant system like to build scale and will cause havock if left to long.One more thing, unfortunately in our cars if you have had a overheating problem and its been serious, chances are you have a bhd
#15 |
![]() Toyota Racing Development Join Date: Apr 2007
Test the thermostat in a pot of water on the stove and use a thermometer to make sure it's opening at the right temp. Details are in the TSRM.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#16 |
Hmm quite the pickle you have there. Having your egr hooked up will definitely help cool things down in your cylinders and take care a pesky nox. Are you having any probs with your cooling fans at all?
#17 |
off topic..
lima ohio.. whats up man! canton here! on topic. overheating issues.. rad cap. thermostat.. leaking lines.. bhg + many more. start at the top and work your way down.
#18 | |
![]() Quote:
the neck bone connected to the... shoulder bone.. shoulder bone connected to the..... has this been checked up on?
#19 |
o man why does it have to be so simular to my problem? lol About a month ago I bought my first car. An '88 supra with a 7mge engine. anyway it overheated on me on my 2hr drive back home and i(my mechanic, i gave up) found out the radiator wasn't pumping out enough coolant at higher rpms. so I switched out the radiator with a all metal one and changed the clutch fan for added safety. As of now i have no heating problems.
Help... my car is overheating | suprra_girl | MKIII FAQ | 40 | 07-11-2010 06:51 AM |
supra overheating | quiky | Non-Generation Specific Questions | 4 | 09-09-2009 11:16 PM |
2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor | V1P3R | MKIII Supra | 9 | 07-17-2007 05:26 AM |
car overheating | marc | MKIII Supra | 11 | 06-30-2006 05:55 AM |
Need Help, Overheating Problems | MDellboy420 | MKIII Supra | 9 | 12-19-2005 06:46 AM |
