-   -   1jzgte Swap questions!! (http://www.toyota-supra.info/forums/mkiii-supra/17605-1jzgte-swap-questions.html)
Travis89Turbo 08-16-2010 01:42 AM
So i have done ALOT of research on the internet and ive learned alot about the 1j swap but have just a few questions i cant find answers for.. There is alot of other forums that get asked these questions but they all say..." do a search to find your answers" there are more answers like that then actual info.:umno:
I need a link or info on a wire harness or adapters between 1jz and ma71 chassis. i dont want to pull my 7m out until i have all pieces to do swap. And dont want to build my own harness but will if it comes down to it. Dont really want to wait a month after receiving my clip.
ive also heard that lengthening the harness is not neccasary if you run harness through speedo hole?? I also heard driftmotion makes adapters for the electrical swap but i have searched the site up and down and cant find them
Also i have a 1989 Turbo A/T built 05/89 is that considered late 89 or early? Will i have to change the cross member? i do have the round style mounts.
Where is everyone buying clips from? i found one at mrjdm for 1900 plus 800 shipping but it takes 2 months to ship because they are based out of japan.
All replies are greatly appreciated!!! Thanks in advance.
spikesnstuff0905 08-16-2010 12:34 PM
Dr. Tweak over at SF will do your splice if you send him both harnesses, i think he charges like 200 bucks, hit him up. Theres a motor imporer in VA called JEI that has 1jz and 2jz's in stock, sold with the motor, tranny, ecu, and bay harness, they can probably get you a whole front clip but you'd have to ask. I'm not sure about the speedo hole thing, so i won't comment on that. Your crossmember should be okay, i don't think it matters as long as your chassis is an 89'. Heres a link to a 1/2jz swap thread on SF. If you have any other questions after you read that.... Sell your car.
http://www.supraforums.com/forum/sho...d.php?t=292754
