Old 08-18-2010, 03:05 AM   #1
zby67
zby67's Avatar
zby67 is on a distinguished road
Unhappy acceleration issues and exhaust leaking
ok first thing is first i would like to thank everyone on this forum for the help though the times iv used this site as research.
hello my name is mike iv owned my supra for 6 yrs now she is my first car and since the first time iv herd her growl i fell in love with the MKIII line lol.
i would like to thank MRnickleye for the tip on fixing the crimped washer on the drive shaft that helped alot and kudos. i originally thought that the noise was the alternator baring going so i got a new one warranted and still the problem went on the shop said it was the timing tensioner but even the shop was wrong and once i got the timing cover off it was that washer and thanks to nickleye its now fixed till i can get a new one.
ok to the problem at hand.
i have no acceleration it feels like im pressing on the brakes and gas at the same time. when we took the timing cover off we also took the radiator off. i blocked both trans lines with bolts so they didnt leak well we were fixing the drive shaft. once we had everything back together we left the radiator off. started her up to see if everything was good. didnt let her run because didnt want her to over heat with everything off and no belts on. everything is back together now and i have bad acceleration. all lines are in there right places and everything in its place. my dad said to check the trans fluid so i did and she was low. i added new trans well she was at idle temp and ran her though all gears 3 times. checked the trans level was ware it was suppose to be so i drove her afew miles to my grandmas house and everything was fine she accelerated nicely no hickups nothing. got to my grandmas house and she was smoking figured it was from the engine burning off coulen't witch was spilled when i went to check the radiator lvl. then i checked the trans fluid lvl and its saying its over filled something that made no sense. so was at her house for a good hr and a half. drove the supra home and i had poor acceleration yet again. when i got home i noticed she was smoking again so i went looking for the source and found out that the exhaust is leaking.
like i said iv been doing research on all this and came up with it being eather the exhaust witch is something my dad says it isnt or its theshift solenoids.
background of the supra
the model of the supra is a MA70 1986.5 supra n/a automatic.
when i got her she didnt run and me and my dad spent a yr bringing her back to life. when i got her there were wires cut under the dash water ware the spare tier sits and a relay running to the starter and to the ignition.
everything is fixed now wires under the dash no more relay and starter is back ware it belongs. i dont get any water in the back of the car sep when im driving in rain but that has been fixed with fiberglass and rubber under coating.
the other problem im having is she dosnt like to start after short distance trips say my house to get gas she will die at the pump. the mechanic i took her to told me that the ignition switch and starter relay were high resistance. and was wondering if anyone knew what the resistance was suppose to be at. also iv replaced all the brackes and brack clips and everything only to find out that all 4 calipers are seazed in place and only move up and down being as the rod from the housing is louse and was wondering if there is an easy fix or do i need new calipers and there housings?
i would be going to the threads that sound the same to my problem and posting all this but there older posts and figured no one would be on them.
any help would me great!
Mike
zby67 is offline   Reply With Quote
Old 08-18-2010, 03:24 AM   #2
Supra Saiyan
Supra Saiyan's Avatar
Supra Saiyan is on a distinguished road
Cre?? Someone!! ANYONE!! Help this guy.. He just wrote a book and the subject he used made me dizzy..
The only thing I could say to help you out friend is either find a mechanic who knows what the hell they are doing or go to a tuner shop.. They usually know what they are doing and can look up things in a snap ::SNAPS FINGERS::! I have been into PRE here in Portland and seen them swarmed with customer asking all kinds of questions. Jason simply looks it anything that's specific like and gives the correct figures.. Amazing I tell you..
Supra Saiyan is offline   Reply With Quote
Old 08-18-2010, 03:32 AM   #3
zby67
zby67's Avatar
Unhappy many thanks, acceleration issues and exhaust smoking
well seeing as i live in the middle of no ware and about 2 hrs away from chicago there isnt anyone around here i would even think or trust to take my car to. the guy who i allowed to work on the wiring under the dash i only allowed to do that cause his son use to own a supra and helped me get the car running when she died at the pump but with being tight on cash and this being the way it is i wouldn't trust him with this work. plus fixing the wires under the dash costed me 400 there.... this is my first car and im protective lol
Old 08-18-2010, 03:37 AM   #4
Supra Saiyan
Oh, your first car.. Shhoot~! No worries. The folks here know quite a bit.. When they notice your post they will most likely reply with some info. It may take a while to help you get it narrowed down but with enough time and research you will be back in your Supra with all the power at your feet!
To help you out. I would put a little detail in your title so when the others see your post they actually want to click on the link to help. It's becoming less and less that these types of post actually get help.. So, click on edit and advanced.. Then change your title.. Then you will get help..
Read this if you want help for description Please use descriptive titles
Old 08-18-2010, 03:45 AM   #5
zby67
zby67's Avatar
thank you for the advice. i changed the title and will keep what you said in mind. the only thing that really concerns me is that i work tomorrow and have no other car and with the exhaust smoking and acceleration issues if its safe to driver her with out something f-----g up. i have no other car to use.
Old 08-18-2010, 03:48 AM   #6
Supra Saiyan
To simplify so your spewing out smoke and spuddering really bad right?
Exhaust spitting 87TT MKIII Supra 16 01-29-2010 07:55 AM
7M-GE issues AFnic MKIII Supra 3 01-03-2008 03:10 PM
Exhaust System SideWinderGX MKIII Supra 8 02-28-2007 08:01 AM
exhaust question (not in exhaust faq) sd88supra MKIII Supra 21 11-28-2006 10:52 PM
5MGE acceleration problems drs77 Non-Generation Specific Questions 3 11-06-2006 11:41 PM
