Old 08-21-2010, 07:07 AM   #1
rohin02
rohin02's Avatar
rohin02 is on a distinguished road
Default Fuel Pump Question...need advice
guys i need to get my fuel pump controller replaced...anyone know where i can find one?
i own a 91 mk3 twinturbo i need it replaced mine is broken it stays on high at all times
rohin02 is offline   Reply With Quote
Old 08-21-2010, 11:49 AM   #2
Travis89Turbo
Travis89Turbo's Avatar
Fuel pump controller? Your fuel pump only has one speed on or off. If u have high fuel pressure you need a new regulator. Or check for linked line under car where it might have came in contact with the asphalt. If ur pump is just really loud then it is on its way out. Walbro can be had for around 100 bucks.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 08-23-2010, 12:55 AM   #3
rohin02
rohin02's Avatar
i appreciate ur reply...
Im trying to get my car to pass air care...it passed the driving test i just cant get it passed the idle test its not going well...my mechanic is telling me that i need to replace the "fuel pump controller" because it stays on high at all times......am i being mis informed? his plan is to find a new one or swap mine with his mk4 supra....i really need help guys my idle test is not going well at all its really high in hydrocarbons etc
Old 08-23-2010, 01:59 AM   #4
Travis89Turbo
Yes u are getting bad info only thing controlling your fuel pump is a relay. I'll let in on a Lil secret first if all give it a tune up plugs, oil, fuel filter, air filter then buy some PURE acetone from your parts store. Put half a gallon in with half a tank of premium gas. Drive it around a Lil bit then test if ya don't pass use more. I've seen it work on cars without catalytic converters. But never done it on a turboed car.. I'm doin a 1jzgte swap right now in my mkiii this is how ill pass due to it not having emission system on it.... but I live in Utah its just a Lil sniffer in the exhaust for a few mins. But im sure this will work for you
stock 2jzge
Old 08-23-2010, 12:39 PM   #5
Green7mgte
Supra Forum Moderator
yea theres acouple posts about this.. do a quick search for Emmissions or NOX and see what pops up brother. lots of helpfull hints on how to either get your car in working order or little tips like altering your spark plug gap.. =) i remeber posting some. Ill see if i cant dig around and make an faq thread about it.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
no power to fuel pump carcrzy920 Non-Generation Specific Questions 0 06-05-2009 05:51 PM
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Pump twin setup drnando Non-Generation Specific Questions 1 02-20-2006 09:27 PM
