need help
hey everyone i recently had a problem with starting my ma70. i found out that it was a ATL relay/ fuse the type is a 1.25B but i cannot get ahold of one so i replaced it with a copper wire. the only problem is that i always have to replace it every few weeks. so i was wondering if anyone knows how i can find one for my mk3? any suggestions
junkyard or someone parting out there supra.
It's just a 100 Amp rated "fusible link" wire.... you should be able to get it from any automotive store although cutting the wire to the right length is tricky. 89+ models used a self contained fusible link which is what is employed in newer vehicles.... you may get one of these and install it in place of the "wire" in the fuse box... it fits perfectly. ;)
| All times are GMT. The time now is 11:17 PM. |
