Old 08-25-2010, 06:45 AM   #1
Supra Saiyan
Supra Saiyan's Avatar
Thumbs down 88 n/a Cam position sensor vs 88 Turbo CPS
Are they the same?
More detail below...
So I want to use an 88 n/a Cam Position Sensor in an 88 Turbo.b. Will this have issues?i Are they the same. All my research points to yes it is fine and they are identical. However,t I am just trying to make sure so I don't have any issues..c Maybe I misunderstood or what...h
HELP..
--Too many drinks tonight--ff wall:
My brain poking at my body right now..
Old 08-25-2010, 11:16 AM   #2
Bill UK
AEM EMS
Bill UK's Avatar
The non turbo 7M-GE has a distributor, the turbo 7M-GTE has a CPS, so I cant see as your findings can say they are the same?
Old 08-25-2010, 08:13 PM   #3
Supra Saiyan
Had to many drinks last night.. Although, now that I think of it.. Are you sure? Because if you remove the distributor and such. I thought I seen a CPS there..
Old 08-25-2010, 09:35 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
Positive..
Old 08-26-2010, 12:58 AM   #5
907mge
907mge's Avatar
The 7mgte has more than one coil pack on top of the engine that provides spark. The cps allows the right coil pack to fire at the right time. While the 7mge uses a distrubuter and only one coil pack.
Old 08-29-2010, 04:38 PM   #6
You can use the GE's distributor in place of the GTE's CPS in a pinch.... they're both cam position sensors, the GE's just has some extra luggage it carries around.
Old 09-10-2010, 05:11 AM   #7
Supra Saiyan
Really? Wow! To bad I am buying a CPS this sunday.. Well, i guess its better that way anyways..
Old 09-10-2010, 05:31 AM   #8
Oh, I really mean only in a pinch... it doesn't fit well by the PS reservoir or the intake piping.... but it does work.
Old 09-11-2010, 01:46 AM   #9
jcastro
is it possible to get the cover for the turbo cam position sensor i cnt seem to get it by itself
jcastro is offline   Reply With Quote
Old 09-11-2010, 04:41 AM   #10
As far as I know the cover and O-ring are still available from Toyota. Someone makes a polished stainless steel cover too.... but I can't remember who makes them or sells them... might be available through ARZ (the only active vendor here at the moment) or possibly Drift Motion.
