I have a 86.5 mk III with a 3.0 engine. The fracker is leaking in the rear of the engine. Riverside Toyota of Tulsa says they have to pull the engine to fix the leak. They want 3k to fix it.
![]() ![]() My problem is do not really know the 3.0 engine very well. I did some work to my 2.0 liter engine the Japanese version. I can not think of anything that would be leaking with the exception of a cover for the cams? Think old age has affected me. ![]()
1986 Mk III MA70 7MGE Targa Top 5 Speed Stock Exhaust ![]() Last edited by Ranma; 08-30-2010 at 06:14 PM. |
AEM EMS
There is an oil seal and gasket at the rear of the engine (see pic below) this is where the crankshaft end connects to the flywheel or torque converter, depending on whether you have a manual or an auto box. I would definitely check the cam cover seals and possible the sump seal for any oil leaks before assuming it’s the rear crankshaft oil seal. Also the 7M engine does slope back at an angle (probably about 5 degrees at a guess) any oil leaks will eventually find there way to the back of the engine.
Bill UK, thank you for your information. I had the rear seals changed when the clutch was replaced by Toyota. They were also suppose to change the cam seals as well. Yes I suppose any engine leak will migrate to the rear of the engine. It is a good size leak and am annoyed that they did not fix it.
I would fix it myself but no longer even have a floor jack. Guess I need to give it the once over myself. Thank you again for your useful information!
1986 Mk III MA70 7MGE Targa Top 5 Speed Stock Exhaust ![]() |
it most likely the rear main seal ive had the same problem. you said you replaced it put the truth is it probably wasnt done right i would try that first because its easy to access and the seal is fairly cheap.
I let Riverside Toyota of Tulsa change the rear main seal when they changed the clutch. You would think the dealer would do a proper job. I know where not to buy my next new car. Suppose I could bring it by the competition dealer. The maintenance "adviser" said something about a seal on the backside of the engine leaking. He said this to me not long before getting sacked. What could he be talking about? He said the engine had to be removed to fix it.
#6 |
AEM EMS
No need to pull the engine to replace the rear crankshaft seal and gasket, especially in a fully equipped professional garage. Remove the gearbox clutch & flywheel and your there. Now if it was the sump (oil pan) leaking at the rear, then you need to lift the engine or remove the front sub frame to drop the sump.
Putting JDM engine in!!! :D | dannydavi | MKIII Supra | 24 | 11-02-2009 06:30 AM |
rebuilt hard to crank (high engine resistance); need advice | cbrewster | MKIII Supra | 4 | 09-28-2009 04:52 PM |
problem seperating engine from manual tranny | Gengus | MKIII Supra | 7 | 01-29-2008 12:10 AM |
