Old 09-07-2010, 06:17 AM   #11
btwilson86
Super Moderator
btwilson86's Avatar
Originally Posted by supraluver4life View Post
we roll started it and I drove it home
If he seized it from that initial drive, would he be able to bump start it?
It's an easy enough test to see if it turns over by hand, so I'd do that first. If that checks out fine, then try Bill UK's test. If still no start, take it in to get tested.
Old 09-11-2010, 08:14 AM   #12
Bill UK
AEM EMS
Bill UK's Avatar
Any feedback on this supraluver4life ?
Old 09-16-2010, 05:03 AM   #13
supraluver4life
supraluver4life is on a distinguished road
So i just changed out the starter and it fired right up. Then i tore apart the old starter and solenoid and the windings had come apart and sieze against the shaft. Seems like that starter had a bad life lmfao. Im not sure how it happened but i know it blew the fuse at the same time. So im assuming a a large power surge somehow and it had just enough time to fry the started before blowing the fuse. Thank you all for the help though. I really appreciate it.
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
Old 05-23-2011, 10:57 PM   #14
interested!
Smile overheating then no starter
So a few days ago I was on a back road up in the mountains and my car overheated. But it didn't just overheat, it overheated then bogged out and died. I went to try to start it and all I hear was a click. So I thought ok so I overheated my starter, then I waited half an hour and the same thing. So we roll started it and I drove it home. Haven't driven it since. So the starter just clicks now when I start it. Problem started when it overheated.
Hi!
I really recommend the relay mod to the starter as mentioned in this forum ,-fitted it myself to my car-what a difference!!- basically there are not enough amps going through the small wire to kick in the solenoid , so it just clicks and clicks and clicks .
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Starter issues! Please help bryanf89 MKIII Supra 4 04-10-2010 05:43 AM
90 mkIII starter connections doodah MKIII Supra 1 11-11-2008 06:14 PM
How to quickly test starter CyFi6 MKIII Supra 4 11-30-2007 01:57 AM
starter removel? swied MKIII Supra 4 04-23-2007 04:50 AM
