Old 08-31-2010, 10:54 PM   #1
brandon bowles
brandon bowles is on a distinguished road
Default Fuel psi
ok i have a 89 supra gt here is what i am running: t60-1, 550cc r/c injectors, walbro 255lph pump, stock intercooler, adjustable fuel pressure regulator, stock manifold, 3in exhaust, stock internals, and think stock headgasket i think the guy that had it built isnt for sure which one so my guess is stock. now what i need to know is what fuel psi do i need to run, oh i am running 9lbs boost for now want to bump it up to 16-18lbs boost. my goal is 400-450rwhp no need for anymore with my lead foot. ANY HELP WOULD BE APPRECITED ALOT. THANKS IN ADVANCE.
brandon bowles is offline   Reply With Quote
Old 09-02-2010, 02:21 AM   #2
Hook up a wide band and figure it out the right (and safe) way. I could tell you 40psi, but every system's different and one persons best might leave you a lean spot.
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
car cranks, but no fuel or spark mustangtw5901 MKIII Supra 17 04-30-2008 07:48 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel injectors redneck ricer MKIII Supra 0 06-15-2007 02:31 AM
