Old 09-02-2010, 03:55 PM   #1
sr20drag
sr20drag is on a distinguished road
Default gear ratios for 90 mrkIII....
What is the rear diff gearing and R154 gearing??
90 model turbo car.
sr20drag is offline   Reply With Quote
Old 09-02-2010, 04:23 PM   #2
sr20drag
I found the r154 gear ratios..
  • First Gear: 3.250:1
  • Second Gear: 1.955:1
  • Third Gear: 1.310:1
  • Fourth Gear: 1.00:1
  • Fifth Gear: 0.753:1
What is the rear diff ratio for turbo mkIII's???
I think the NA's are 4.30's
Old 09-02-2010, 05:22 PM   #3
Green7mgte
Supra Forum Moderator
supra wiki. or if you bothered to check the faq.. you would of seen it.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 09-02-2010, 05:37 PM   #4
sr20drag
I found it...
http://www.toyota-supra.info/forums/...ing-ratio.html
thanks
harmonic balancer came off crank shaft help? wishiknewmore MKIII Supra 3 04-15-2011 11:04 AM
Speedometor / Ma70 Gear ratio cre MKIII FAQ 4 08-24-2010 04:14 AM
1st gear jumping out, 4th gear crunching, how do I fix it without changing gearbox wcrispino Non-Generation Specific Questions 7 01-31-2010 11:13 AM
quick question blacksheep Non-Generation Specific Questions 10 01-01-2007 08:19 PM
Lots of gear ratios.... Isphius MKIII Supra 2 08-27-2006 03:13 AM
