Old 09-06-2010, 06:27 AM   #1
wayzhack
wayzhack is on a distinguished road
Default 7mgte to 7mge conversion help
Yeah you read that right. Well actually I dont have a 7mgte engine, but Im trying to drop a 7mge engine, tranny, and ecu into a 1988 Toyota Supra Turbo shell.
Anyway, from what Ive read on here, I can pretty much bolt on the new tranny and engine, but what I need to know is if there is anything else that I will need for the conversion? My main question is: Will I be able to use my turbo harness for the n/a engine, or will I need to go buy a 7mge engine harness?
Once again the car is set up for a 7mgte turbo engine and 5spd transmission, but I am swapping in 7mge non turbo engine and auto transmission.
Yeah i know thats a totally hideous thing to do, but thats the cheapest option to get the car running while I save up for the 7mgte or 2jz...
Can't wait to get that 7m!
http://sites.google.com/site/wayzhackimportzone/
wayzhack is offline   Reply With Quote
Old 09-06-2010, 02:31 PM   #2
blake
blake is on a distinguished road
first question is what yr is the shell? if it is a 89+ you will need the harness of the shell and if you can locate a harness for the na of that motor and trans set up u will be in good water, here is a link i have for i am doing a reverse swap my self a 91na with a turbo 88 droped into it full swap of ecu harness trans and a few other little goodies, but since the <88 are different then the 89+ the harness will not plug into the dash hence this link, http://members.shaw.ca/boltz/7MGTE-S...TE,%205MGE.htm will help look at the pin outs, and the turbo harness on a na, there are many things different, example the na has a diffent afm, also no coil pack's, are you going from a 5speed to an automatic? we need detail's... yrs of everything, and it isnt a conversion but a swap.
blake is offline   Reply With Quote
Old 09-06-2010, 05:43 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Looks like your question was already answered...
There it is again, it's like he is psychic; your questions were answered before you asked them
Blake, thanks for posting some info for the OP. Please be sure to read the post throughly so that there are no repeated questions or missed information.
Old 09-06-2010, 11:13 PM   #4
The thing that needs to be asked here FIRST is just how temporary is this or how much do you want the GE to perform like it should in a MKIII?
Old 09-07-2010, 01:01 AM   #5
wayzhack
Default lets see
Yes, as stated before, I want to swap an automatic non turbo 7m-ge engine from a 1989 Toyota Cressida into a 5spd 1988 Toyota Supra Turbo shell.
The 7M-GE engine comes with an automatic transmission and ECU from the same Cressida.
The goal is simply to get the car running as cheaply as possible while saving up for a jdm 7M-GTE. Since I'm going back to school, this could take a while but I would have enough money within the year for sure. Therefore since its only temporary, I'd rather not have to splice the turbo harness too much or something.
Recap:
1989 Cressida 7mge, a/t and ECU into 1988 5spd Supra Turbo shell.
For temporary use (less than 1 year)
I dont know if I can be any clearer. Any other questions?
Old 09-07-2010, 03:52 AM   #6
I asked a question you did NOT already post and answer to and for a VERY specific reason... I was trying to determine just how much effort you were looking to invest PHYSICALLY. If this were for the long term my answer would have been different than the short term....
Knowing that the GE is from a Cressida makes a bit of a difference too... but ya know what, forget it. You haven't the patience to answer NEW questions and I haven't the patience to wait for you to get past that.
Good luck with the project.
Old 09-07-2010, 06:22 AM   #7
btwilson86
Super Moderator
btwilson86's Avatar
In order to do your swap easily (if you can call it easy), I'd start by removing the 7MGTE from the engine bay with it's wiring harness attached (just push the ECU plugs through the firewall and unplug the few remaining body connectors).
The turbo harness and ECU will not be able to be used on the 7MGE.
When you install the 7MGE and A340E, install it with both the harness and ECU from the Cressida (I can't remember off hand, but I think there is an additional transmission computer that you'll need to swap in as well). After putting the few odds and ends together, and getting through the unforseen difficulties, that should give you a decently operating drivetrain in the Supra without damaging or modifying most of its components for when you get that JDM 7MGTE.
Old 09-07-2010, 08:22 PM   #8
wayzhack
Default Canceling the swap
woah alright dude no need for hostility. My post was just to make things perfectly clear that I thought may not have been clear already due to Blake and your posts. Within my post I gave you a clear answer and also asked for any other questions which needed answering. Im just trying to be clear and give as much info as I can so that I can get some help, but I'm sorry if you somehow took that as "not having enough patience".
As I said before, the shell doesn't have a 7mgte in it because it is a shell. I do however have the 7mgte harness. I also dont have the harness from the cressida. I only have the 7mgte shell, 7mgte harness, 7mge engine, 7mge tranny, and 7mge ECU.
Anyway, I have decided that I'm not going to be doing the swap after all. I'm just going to continue saving up for a 7mgte. However I would like to thank all of you for posting and helping me figure out how much trouble it would be! lol And I'm sorry if I've offended anyone through my posts, because that was not my intention.
Tags
7mge, 7mgte, conversion, engine, harness
Rumours of 7mge and 7mgte supraman121 MKIII Supra 4 04-23-2007 01:55 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
7mge to 7mgte kallmijonx2 MKIII Supra 2 10-22-2006 12:55 PM
7mge vs. 7mgte KNYFE MKIII Supra 3 09-27-2005 02:21 PM
