Old 09-07-2010, 10:08 AM   #1
ochowdero
Default ooh boy, auto to manual tranny swap question.
i want my 87 supra (N/A) to be manual.
whats the best route to take.
there is no way to trade the car for a 5 speed, or buy a project 5 speed either.
so what can i do?
this is a really big issue for me..
can i take a transmission and motor out of a similar car? if so would it be worth it?
any help please, like ive said this is a really big issue for me...thanks
Old 09-07-2010, 10:40 AM   #2
ochowdero
bump bump!
Old 09-07-2010, 11:49 PM   #3
Sonyps307
You can swap a 5 speed in but you need all the parts like transmission, clutch, clutch pedals, master and slave and hard lines And you have to do something else to the wiring I think to
Old 09-08-2010, 12:01 AM   #4
ochowdero
i know that, but nowadays you can seldomly get ahold of a supra 5 speed tranny...
is there any other car i can take the tranny out of?
Old 09-08-2010, 12:21 AM   #5
Sonyps307
Toyota Cressida some years had 7mge in them
Old 09-08-2010, 12:28 AM   #6
you need:
w58 5 speed transmission
front half of drive shaft from a 5speed
clutch and brake pedals from a 5 speed
hard line that goes from master to slave clutch cylinders
master and slave clutch cylinders (i would buy new)
Clutch and flywheel for w58
what would be nice:
radiator from a 5 speed.
all rubber boots to protect from dirt and leather shifter boot.
and of course you need to trick your neutral safety start switch:
remove this from your auto tranny and plug the wires back into your engine harness in the P Park position, or the car will never start.
good luck.
did i miss anything??
Old 09-08-2010, 12:47 AM   #7
ochowdero
thanks. where can i find the wh8?
easiest
haha
this was good thank you,
i new what i needed but miss acouple things.
should i find a junk cressida and take the tranny out of that?
Tags
mk111 mkiii mk3 tranny
Engine harness question between auto and manual gambit1982 MKIV Supra 4 05-25-2010 05:34 AM
auto to manual tranny swap sd88supra MKIII Supra 10 11-24-2009 06:25 AM
Question about switching an auto tranny with a manual one TehEl1te MKIII Supra 2 10-21-2009 09:45 PM
Difficulty of changing tranny from auto to manual vas85 MKIII Supra 2 06-03-2006 08:30 AM
