i want my 87 supra (N/A) to be manual.
whats the best route to take. there is no way to trade the car for a 5 speed, or buy a project 5 speed either. so what can i do? this is a really big issue for me.. can i take a transmission and motor out of a similar car? if so would it be worth it? any help please, like ive said this is a really big issue for me...thanks |
bump bump!
You can swap a 5 speed in but you need all the parts like transmission, clutch, clutch pedals, master and slave and hard lines And you have to do something else to the wiring I think to
i know that, but nowadays you can seldomly get ahold of a supra 5 speed tranny...
is there any other car i can take the tranny out of? |
Toyota Cressida some years had 7mge in them
#6 |
you need:
w58 5 speed transmission front half of drive shaft from a 5speed clutch and brake pedals from a 5 speed hard line that goes from master to slave clutch cylinders master and slave clutch cylinders (i would buy new) Clutch and flywheel for w58 what would be nice: radiator from a 5 speed. all rubber boots to protect from dirt and leather shifter boot. and of course you need to trick your neutral safety start switch: ![]() remove this from your auto tranny and plug the wires back into your engine harness in the P Park position, or the car will never start. good luck. did i miss anything??
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
#7 |
thanks. where can i find the wh8?
easiest haha this was good thank you, i new what i needed but miss acouple things. should i find a junk cressida and take the tranny out of that? |
Tags |
mk111 mkiii mk3 tranny |
Engine harness question between auto and manual | gambit1982 | MKIV Supra | 4 | 05-25-2010 05:34 AM |
auto to manual tranny swap | sd88supra | MKIII Supra | 10 | 11-24-2009 06:25 AM |
Question about switching an auto tranny with a manual one | TehEl1te | MKIII Supra | 2 | 10-21-2009 09:45 PM |
Difficulty of changing tranny from auto to manual | vas85 | MKIII Supra | 2 | 06-03-2006 08:30 AM |
