Old 09-10-2010, 09:06 PM   #1
gorillaguy8
gorillaguy8's Avatar
gorillaguy8 is on a distinguished road
Default Clutches
Im swaping out my W58 transmission for a R154. The W58 wont shift into any gear anymore, but luckily I have the R154 out of my donor car. I was told by a friend of a friend who had a supra at one time that the clutch is interchangeable. I dont trust him very well so im wondering if any one else knows for sure. Every where i look there are different clutches for Turbo & N/A. What kind of performance clutches do my supra friends have out there? Any suggestions? Im not looking to spend a ton of money just enough to get one that will last and be durable
Black 87 N/A, re-built from the ground up.
gorillaguy8 is offline   Reply With Quote
Old 09-11-2010, 09:18 PM   #2
ochowdero
you have everything hooked up?
from what people have been telling me, i need to have a specific clutch and brake set...im not totally sure, cre should definately tell you..i trust him..
btw, im bumping this for you
Old 09-11-2010, 10:43 PM   #3
Travis89Turbo
Travis89Turbo's Avatar
No those clutches do not interchange the r154 is a pull type clutch rather then the standard push type... if u have a donor car and u have to pull both trannys might as well put the r154 tranny flywheel and clutch in ur car? Oh and the driveline in it its a little shorter but use the whole driveline and mark it so it goes back exactly the same cuz they are balanced as a whole.... r154 is the best tranny Toyota ever made..almost bullet proof people run over 900hp with them with just an upgraded thrust washer
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Clutches carfanatic89 MKIII Supra 6 10-20-2007 10:49 PM
Best Performance Clutch SilvaT MKIV FAQ 32 02-22-2007 02:05 PM
auto tranny work mizuboi MKIII Supra 16 01-03-2007 10:46 PM
