Old 09-09-2010, 09:16 PM   #1
ochowdero
Default CAI, info
so i know how to make one.
well kinda,
should i just go out and buy one for 118$ or make one for 25$ maybe even less?
if i made one
there are 2-3 hoses attached to the stock filter box, how do i hook that up?
and do i need a box around the (CAI) filter ?
if so can you post a pic up please, to send me on my way
i know what to do just wanna be 100% sure
Old 09-09-2010, 10:54 PM   #2
Busted Knuckles
Busted Knuckles's Avatar
You can make one if your handy enough. Spectre makes a kit with elbows and straight pieces that can be cobbled together. Even includes pieces with pre-fabbed holes for the various air lines you mentioned. http://www.spectreperformance.com
A couple of key points. All the air lines that are stock-located after the MAF sensor must remain after the MAF sensor. Capping them off is a bad idea, and leaving them open will confuse the ECM. Any air leaks between the MAF sensor and throttle body will also confuse the ECM, so make sure it all seals well.
The purpose of a CAI is to draw cold air. So, you either need to box in the filter or run it out of the engine bay and away from engine heat. I've seen these run into the inner fender area behind the inner fender liner and in front of the radiator. Just make sure you don't run it too low. It would suck to hydrolock the engine hitting a puddle at speed.
Old 09-09-2010, 11:56 PM   #3
Hitting a puddle doesn't do a thing... a flash flood pond and you're screwed... BUT There are intermediate relief inlets you can add to prevent such suction from pulling in any significant quantity of water; the most common is a cylindrical air filter that's fairly dense so air isn't pulled through it unless the regular one is somehow clogged. This one you install at a high point in the middle of the piping.
AEM makes one: http://www.aemintakes.com/search/product.aspx?Prod=20-402s
Tags
cai intake filter
Need some parts info Knightryder MKIII Supra 12 03-24-2008 04:49 PM
info on 1984 supra 84cuddy MKII Supra 1 11-22-2007 11:00 AM
Info on MkIII Supra Nic MKIII Supra 2 03-15-2007 11:27 PM
Emissions Test Info in "Your" Area/State mrnickleye Supra FAQ 0 03-05-2006 06:01 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
