Old 03-06-2009, 04:52 PM   #1
georides
georides's Avatar
georides is on a distinguished road
Default Reverse Light Switch - The where and how
Greetings from NJ USA
87 Supra Auto non turbo
All lights work except the reverse lights, removed left side bulb, high rust in bulb socket, right side is OK, though no power when shift lever in reverse.
Will I be looking to the shifter console for the switch or "undaneath" down by the tranny.
Thank you for the werds
georides is offline   Reply With Quote
Old 09-12-2010, 03:32 AM   #2
Suprasexy
Suprasexy is on a distinguished road
i had the same problem with my supra, and im betting the reverse light connector above the tranny has come undone and needs to be plugged back in, so you'll have to drop the tranny and do that which kinda sucks, but i had to do it too=(
hope this helps if you havent done it already!
Suprasexy is offline   Reply With Quote
