Old 09-19-2010, 05:00 PM   #1
porsche944god
porsche944god is on a distinguished road
Default Got no spark!!!
1987 supra was looking for amp draw....pulled fuses out and nothing changed replaced interior fuses and wahla! no spark but got fuel need help i think its computer but not sure
porsche944god is offline   Reply With Quote
Old 09-20-2010, 12:57 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
my first guess would be the 15 amp efi fuse in the engine bay
Old 09-20-2010, 01:06 AM   #3
porsche944god
well it has no blown fuses whatsoever and the main relay under the hood is not clickin on or off jumped it it would start but rev up to 2000 then back down 1100 then back up.....without it jumped the car has no spark but is getting fuel
Old 09-20-2010, 12:51 PM   #4
try putting in a new main relay then.
think there like 20 $
Old 09-20-2010, 03:11 PM   #5
porsche944god
They relay is still good i moved it to a spot on the inside panel and it clicks....i have power on the "engine" fuse and ecu-ig fuse both sides like i said will run as long as the main relay is jumped will not if everything is like it should be ....i actually while it was running took the ecu-ig fuse out and nothing happened also did the same with the engine fuse. If it is the computer i have no idea how it would have burned up, also doesnt it mean the ecu is bad when u turn on the key and the check engine light does not light up? cuz it did b4 i started tryin find the amp draw.
Old 09-20-2010, 05:36 PM   #6
btwilson86
Super Moderator
btwilson86's Avatar
It sounds like you must have a break in the wiring after the EFI fuse. Once you jump the relay directly, pulling the fuses wouldn't do anything because they are no longer supplying the power, your jumper wire is.
Check for voltage at the + input for the relay's internal coil (normally an 85 or 86 if it's marked). If there is power, check the relay coil's ground wire for continuity with the chassis ground. One of those should fail, when it does start tracing that wire to find either the faulty switch/relay or break in the wire
Old 09-20-2010, 05:46 PM   #7
porsche944god
I can pull the efi fuse out and it dies .....and there is only power on one of the terminals where the relay goes but its hard for me to think there is a break anywhere tho considering the car ran fine up until i pulled the fuses out of the interior panel....and there is no check engine light could that be caused by faulty ecu? From what i gathered from schematics that light circuit comes directly from ecu.
Old 09-21-2010, 03:08 PM   #8
porsche944god
Well thanks for your help, some how i over looked the 7.5 ig fuse in the inside fuse panel lol of coarse how it was blow was hard to see now im back to square one......i need a w58 tranny!
Old 09-21-2010, 10:50 PM   #9
good luck.
ive been lookin for one for my mk2 for months...
Help...My spark plugs are in the oil !!! chinesedawn MKIII Supra 6 10-03-2011 09:25 PM
87 non turbo drove then died now no spark newtosupras MKIII Supra 1 02-25-2010 07:10 AM
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
