Old 09-09-2005, 06:16 AM   #11
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
general rules to smoke
white smoke on startup/cold mornings = normal
white smoke constantly = bhg
blue smoke constant under acceleration = piston rings worn
blue smoke on startup = valve seals generally
blue smoke at idle but not under acceleration is generally turbo seals
blue smoke on deceleration = turbo seals
grey smoke on acceleration = tune your car
grey smoke at idle while idle rpms are all over the place = fix your boost leak
(testing the turbo) make sure your car is warm.... rev it slowly and hold it at about 2000rpm
then drop the throttle back to idle... does it then piss out with smoke? if so then more than likely your turbo seals are dead
that help?
Pics of my build.
Do a diagnostic first!
Old 09-10-2005, 06:04 AM   #12
Poodles
Poodles is on a distinguished road
Pull your accordian hose and look and see if there is a ton of oil in the hose and the turbo, pretty easy to do and wouldn't hurt to clean it out. You can also check the freeplay and condition of the turbo. Turbo seals are cheap, broken blade on the turbo aren't (gotta get a new turbo, grrrrrr)
Poodles is offline   Reply With Quote
Uprgraded 60-1 turbo smokes supersupramk3 MKIII Supra 1 10-19-2008 12:00 AM
1991 Turbo Supra Smokes When Starts Getphazed Non-Generation Specific Questions 5 10-08-2005 03:28 AM
