Old 12-07-2004, 11:23 AM   #2
Jester
Jester is on a distinguished road
up grades.... it depends on what u wanna do. showroom, racing, burnout.... u need to decide what the car is for then research the parts. yes it can be turbo'd. compression... anything under 9:1 is not so good. 10:1, 10.5:1 11:1 are much better... if its a giveaway, something will be wrong. no one gives away a perfectly good working car that is only 13 years old. it was probably in an accident or has internal damage
Jester is offline   Reply With Quote
Compression check when cold gottadiesel MKIII Supra 3 02-26-2009 07:24 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
Compression Question Intenseneal MKIII Supra 5 08-15-2005 10:27 AM
