Old 09-27-2010, 04:21 PM   #1
donbrown92
donbrown92 is on a distinguished road
Default 1989 mk3 supra
My dashboard lights will not work and I don't know if its the dimmer switch or just a fuse because the turn signals work and all the other lights come on but the actual light so you can see how fast your going and etc. are not turning on. Help????
donbrown92 is offline   Reply With Quote
Old 10-08-2010, 05:46 PM   #2
Metaphysico
Metaphysico is on a distinguished road
If its just the light for the speedo and tach then its probably a bad bulb, if none of the lights come on in the dash, ie fuel, boost, temp then you should look into the rheostat (dimmer switch).
Metaphysico is offline   Reply With Quote
Old 10-08-2010, 05:51 PM   #3
fantasma87
fantasma87's Avatar
if non of the cluster lights and the corner lights on the bumper dont work but you headlights does , verify the light relay on the engine bay. good luck . Q
ARMY STRONG !!
Tags
1989, dash, fuse, lights, supra
What's the value of a 1989 Toyota Supra? MysticKnight MKIII Supra 14 02-13-2011 05:26 PM
1989 Turbo Supra FS 95% complete TehEl1te Buy/Sell Cars 8 06-15-2010 08:26 PM
My lucky find: 1989 Toyota Supra Turbo seken-cole Show n Tell 7 05-23-2010 10:55 PM
Mint 1989 supra found. Need quote on re-torque whowouldfigga Non-Generation Specific Questions 2 02-05-2008 01:57 PM
