Old 09-29-2010, 03:24 PM   #1
hemi34
hemi34 is on a distinguished road
Thumbs up idle surging up and down when warm
After searching the forum for an answer to my problem I could not find one, I have this problem when my 90 non turbo supra warms up it jumps from 800 rpm to 1500 rpm continuously, I replaced the tps and adjusted it, but it did not fix it, I took the IAC valve apart and cleaned it but that did not fix it either. I took the IAC valve back off and then took the stepper motor apart, I found the lower bearing was frozen solid, moisture had gotten in there and stuck the bearing, I sprayed the bearing with rust disoverer and then carefullly turned the rotor back and forth, I kept doing it until finally it would spin freely. It should be free enough that when you bolt the valve back on you can push the valve in and out, it fixed my idle problem and helped the cold start idle also. I hope this will help someone else.
David
here is a link to the valve picture you will see the rotor in the top half.
http://www.cygnusx1.net/Supra/Librar...spx?S=FI&P=106
hemi34 is offline   Reply With Quote
Old 09-29-2010, 04:20 PM   #2
nice research.
and thank you for sharing your findings!
