Old 09-29-2010, 05:42 PM   #1
MA3Edwards
MA3Edwards's Avatar
MA3Edwards is on a distinguished road
Default Idles high
Hey. Kinda new. I had my 1989 Supra for about 7 months now and up until the past week it has run perfectly fine. But like I said for the past week os so,my Supra has been idling around 2500-2800 RPM. I look up some common causes to this and I found all kinds of post and sites saying it should be the mass air flow sensor or something along those lines. I jsut wanted to know if anyone has any similar problems or if someone might know how to go about in starting to fix it. I'm no mechanic but I can usually find my way around a car. I just don't want to start tinkering with it and end up making it worse than it is.
MA3Edwards is offline   Reply With Quote
Old 09-29-2010, 05:46 PM   #2
hemi34
hemi34 is on a distinguished road
I would check the IAC valve and see if it is stuck like mine was, see Idle surging, also check the intake boots for cracks, hope this helps.
David
hemi34 is offline   Reply With Quote
Old 09-30-2010, 12:30 AM   #3
Check for error codes, test TPS (the idle switch, IDL ), check for vacuum leaks and test the IAC and AFM. I would do it in that order.
Old 10-02-2010, 02:43 PM   #4
MA3Edwards
MA3Edwards's Avatar
thank you for the advice. ill get started on it and see what all i can do. thanks again.
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
hesitation, high cold idle and poor gas mileage sd88supra MKIII Supra 14 02-06-2007 04:17 AM
high idle adamh88 MKIII Supra 3 08-17-2006 08:36 PM
