Old 10-08-2010, 12:44 AM   #1
Ranma
Ranma's Avatar
Talking the shakes
Riverside Toyota has decided the drive shaft is not the cause of her vibration. Last I heard the mechanic is pulling the axles and maybe even the "pumpkin" to determine the cause. If this was not so tragic it would be funny. I will let you know what they discover.
Old 10-08-2010, 01:09 PM   #2
fantasma87
fantasma87's Avatar
look at it on the right way , they are giving your car a good inspection at least. but hopefully they wont charge for all the labor. did they check for the wheel bearing on the hubs? good luck . Q
ARMY STRONG !!
Old 10-08-2010, 01:14 PM   #3
its not the center bearing on the drive shaft??
also what 87 said, check outthe wheel bearings.
would probly be a good idea to check tire pressure, and balancing, all these things could cause wobble and poor gas efficiency.
Old 10-08-2010, 02:03 PM   #4
Ranma
Ranma's Avatar
Talking
No the drive shaft was checked out in a shop. So he is pulling the axles and checking the bearings. I threatened to change the registration infomation and named the dealership address as the cars.
I changed the wheels to the factory ones and thus they were balanced. She has had an alignment. IE they changed the inner tie rods and boots just before the rack blew out.
As I said, once is accident, two time is coincidence and third time is comedy. I know where not to buy a new car!
Old 10-09-2010, 12:32 AM   #5
Ranma
Ranma's Avatar
I just discovered the drive shaft came from a ford It has been butchered to fit in my Supra. Well I ordered a rebuilt one for my car. Ick get that thing from my car!
Old 10-09-2010, 12:33 AM   #6
lol well that sucks, i hope you get it sorted out.
Oh no he isn't! Oh YES I AM! Vacationtime247 MKIII Supra 83 09-01-2010 02:44 AM
Sc300 Midengtoy Non-Generation Specific Questions 3 12-13-2005 03:32 PM
I've got the shakes! entropysix MKIII Supra 3 12-11-2005 08:14 PM
