Old 10-08-2010, 09:26 AM   #1
Cyto
Cyto's Avatar
Cyto is on a distinguished road
Default What the sh*t..
Okay, well I've tried everything.. and frankly, I am giving up.
The Supra has beaten me once again. I have a new problem.. lol
Well.. here it goes- The car just doesn't wanna go. If I pat the peddle it will go, but if I press it like a normal car, it just da da da da and shakes and the turbo spools, and it makes it worse. I don't even know how to explain this problem..
Once I get it up to speed, I floor it and the turbo spools up to about 6 psi, it goes nuts. It feels like fuel cut, the car misses, and it actually slows down! >.<
If I let it idle in park, press the brake put it in Low, let off the brake and floor it. It just moves very slowly and sounds like 2 or 3 cylinders are missing. I can't explain it. I've changed the plugs a few times.. every time I pull them they are black all over. My mechanic friend said he thought it was the valves, not releasing the exhaust correctly. I think it's a vacuum leak, or something simple. It all started happening after I changed the fuel filter. I checked the lines and they were kinked at first, but it only solved it a minor little bit. Still.. It does the same thing. I've quadruple checked all the vacuum lines..
Any suggestions?
Proud owner of a 1988 Toyota Supra Turbo, 105k Miles, and great condition.
I might have to sell it to help pay for school so here's the link.
http://www.toyota-supra.info/forums/...html#post72357
Cyto is offline   Reply With Quote
Old 10-08-2010, 01:04 PM   #2
fantasma87
fantasma87's Avatar
i cant remember but the fuel filter is it one way or it can be use any way? maybe its on the wrong way. restricting fuel to the line. that same problem happend to me but it was when i whashed the engine one time, water pass through the cover of the spark plug on top of them and it was the same problem. hope you fix it and its nothing big . good luck . Q
ARMY STRONG !!
Old 10-08-2010, 02:09 PM   #3
Metaphysico
Metaphysico is on a distinguished road
Check for leaks in the ic system mostly the one that comes off the bottom of the turbo and the one that goes into the Ic itself. It will make for problems when you are under any load at all or under vacuum.
Metaphysico is offline   Reply With Quote
Old 10-09-2010, 04:52 AM   #4
Cameroonski
Cameroonski is on a distinguished road
Is it the original fuel pump? And how dirty was the filter? When i replaced my fuel filter, it had a fair amount of gunk in it. The next day my pump went out. There was more load on it because of the clog and when it was freed it just burnt up or something a day later. There is a chance your pump is freaking out because of your newly free flowing fuel filter. Just an idea if nothing else ever comes up, you can get a pump for not to much. I got one one ebay for like 25 or 30 dollars including shipping. Just a thought
Cameroonski is offline   Reply With Quote
Old 10-09-2010, 05:07 AM   #5
check out ic piping as said, and all vacuum lines first it would be cheapest.
cant remember but i think there is filters on the injectors themselves, an idea but its easier to check them than the tank.
and if all else fails check out fuel lines and pump, there is a way to test fuel pump with the diagnostic box.
Old 10-09-2010, 11:48 PM   #6
Cameroonski
The diagnostic box terminals to test the fuel pump is Fp and b+ I THINK... its been a while. you do this with the key at the on position and the car off, and it essentially turns your pump on. It sounds like the pump is working well enough, however, because the car wouldnt run at all if it wasnt.
Old 10-10-2010, 06:51 PM   #7
Error codes? Have you tested the AFM and the knock sensors and their wiring?
If it's doing this off-boost as well you can just skim over the IC piping for any large holes in the system.
Old 10-12-2010, 07:02 PM   #8
kamikazemkiii
kamikazemkiii is on a distinguished road
Take pics of the plugs, and a possible video. Is the check engine light on?
kamikazemkiii is offline   Reply With Quote
Old 10-12-2010, 08:03 PM   #9
The check engine light is not an effective diagnostic tool... there are very few codes which will trip it and even fewer which will cause it too remain on. ALWAYS check for codes.
Old 10-13-2010, 03:51 AM   #10
Cyto
Cyto's Avatar
Theres still a code 52, like there has been for over a year now. I fixed it a while back. The knock sensor under the manifold was disconnected. And it didn't help anything.
It looked as if the fuel filter had never been changed.. if it weren't for the AC Delco emblem I would think it never had been.
The only leak I could think of would be on the accordian hose to the inlet of the turbo, there is a small crack and it doesn't even come off of the inlet to take in any air.
I'll patch it up to see what it could be doing. This has been going on for a long time, and its pissing me off. I'm about to just give up and do a complete swap.. >.<
