#11 | |
![]() Quote:
http://www.youtube.com/watch?feature...&v=7XTrPKt9Tnk This was caused from a hole in a piston. White as can be... Also when my turbo oil seals went out it was white also. The color of smoke is a rule of thumb not written in stone anywhere 160k is pretty good out of rings if it wasn't cared for properly... and again BHG won't lower the compression that much..IMHO
1995 Toyota Supra SE 71k miles. Master power T70 stock 2jzge 1989 Toyota Supra. 1jzgte swap 5 speed of course.. Driftmotion 60-1 single turbo kit. Cxracing FMIC. 2jz 550cc injectors... soon to come..... EMS Stinger. BC 264 cams 680cc injectors Spec stage 4 clutch and A LOT of boost!------SOLD 1999 Ford F350 diesel 2004 Jaguar XJR Supercharged If it hasnt broke you haven pushed it hard enough!! |
#12 |
160'000 to have bad rings you would need to have putting the wrong oil in for 10 years or somthin??
does the 1j also have a ct26? because there antifreeze cooled. if the seals were gona bad enough could antifreeze be forced into the head?? that is some mean smoke comin from ur 1j
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
#13 | |
![]() Quote:
1jz use twin ct12a turbos. but they are antifreeze cooled.. my turbo that went out was on my old 7mgte. it was just the oil seal that burned out. The only way antifreeze would burn from the turbo is if it leaked into the oil passages and the oil seal was burned as well.. 160k miles is 257,495 km. So it is definatly not un heard of to have rings go at that many miles if oil has not been changed regularly
#14 |
oh ya i forget you Americans use miles,
we igloo people use kilometers so yea... my bad
#15 |
Hey so Ive never changed piston rings before.. Was wondering if anyone could load some pics of the process. thanks for the help so far guys. appreciate it.
#16 | |
![]() Toyota Racing Development Join Date: Apr 2007
![]() Quote:
Coolant is water, glycol and sulfates. When burning coolant you're looking at mostly steam, go boil some water and report back please.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#17 |
Oil burns blue normally, coolant is white, unburnt fuel is black. But when you have a lot of oil burning it will be white and it will be a lot of smoke. My turbo went out and it was blowing a lot of white smoke, but I burnt 1.5qt of oil in 30 miles.
Thread Tools | |
Display Modes | |
Cylinder Compression Values | SupraSleuth | MKIII Supra | 6 | 08-17-2009 11:53 AM |
Compression and Block Tests | mrnickleye | Supra FAQ | 0 | 01-29-2007 03:49 AM |
Just did compression test...Help with oil pressure! | 2JZEFINI-17 | MKIII Supra | 1 | 11-06-2006 12:06 AM |
87 Toy Supra N/A, Running on 4 Cylinders | wilvelas | MKIII Supra | 5 | 04-24-2006 02:40 AM |
Compression Question | Intenseneal | MKIII Supra | 5 | 08-15-2005 10:27 AM |
