Old 10-08-2010, 01:30 PM   #1
86.5Supra09
86.5Supra09 is on a distinguished road
Default Low compression 2 cylinders
Hey guys I have an 86.5 MKIII and did a compression check with the #4 & #5 were low. I think the #4 was 120psi and the #5 was only 90 psi. What could be the problem? Rings? HG? Any help would be great!
Thanks!
86.5Supra09 is offline   Reply With Quote
Old 10-08-2010, 03:00 PM   #2
Metaphysico
Metaphysico is on a distinguished road
If your compression tester is like most it has an air chuck fitting on it, take the schrader out of the hose and the radiator cap off and hook an air line to it while its on the worst cyl. If the coolant starts to overflow or bubble then you have a bhg. Either way with those values I would think bhg, rings are not normally a problem on these car, or at least you will have lower values in all the cyls. Also bent valves don't normally happen so that should not be an issue either. If you want to check the rings, put a small amount of oil or trans fluid in the cyls and redo the compression test, if you get a large increase in compression it will be rings..
Metaphysico is offline   Reply With Quote
Old 10-08-2010, 06:38 PM   #3
Travis89Turbo
Travis89Turbo's Avatar
It's your piston rings. They don't always show low on all cylinders. 90psi. is definatly not caused from a bad heasgasket. But since it is free to test it. its worth a try. but I got 100 bucks on rings... rings wear out on any car regardless of make. Although they are not as prone to ring problems as they are bhg. They do wear out. In your situation is say rings.. especially unit has high mileage. Or has the boost cranked up above stock
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 10-08-2010, 08:12 PM   #4
86.5Supra09
Sorry I forgot to add that its a non turbo car.. has a little under 160,XXX. Ive been told from numberous people its either the rings or BHG. I was thinking about buying that "Blue Devil" sealant for the mean time, but I was trying to confirm it was a BHG. I dont really want to have to take apart the head because I want to do a 1jz swap in a month or two. But if it is the rings then Ill have to take the head off.
Old 10-08-2010, 08:13 PM   #5
86.5Supra09
Also it has some white smoke when I start it up coming out of the exhaust, I normally only drive it around town once a day.
Old 10-08-2010, 09:09 PM   #6
Travis89Turbo
White smoke is a sign of piston rings. Blue smoke is sign of BHG. Like i said. bhg won't affect the compression by that much... jz swap is coming early..you will love it. I love my jz..
stock 2jzge
Old 10-09-2010, 01:15 AM   #7
86.5Supra09
Where did you get your JZ? I was looking online.. the cheapest i can find one with motor and tranny is like $2100... like $1400 for just the motor. Know of anyplace cheaper? trying to buy from a direct source that has a warranty incase anything happens.
Old 10-09-2010, 01:35 AM   #8
Travis89Turbo
http://www.jrautoparts.com/clip_toyota_1jz.htm
3k shipped. No warranty but he sent me a video of it running. Trust me if u dont buy a front clip a 4 day project will turn into months trying to get all the little pieces
stock 2jzge
Old 10-09-2010, 02:14 AM   #9
i was told white smoke was antifreeze, and blue smoke was oil...
doesnt make sense either that 160'000 would have bad rings...
ive had 4 supras and never experienced bad rings, my 85 2.8 was running 360'000km and still running strong
Old 10-09-2010, 03:25 AM   #10
btwilson86
Super Moderator
btwilson86's Avatar
Yup, you've got it right
Cylinder Compression Values SupraSleuth MKIII Supra 6 08-17-2009 11:53 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
87 Toy Supra N/A, Running on 4 Cylinders wilvelas MKIII Supra 5 04-24-2006 02:40 AM
Compression Question Intenseneal MKIII Supra 5 08-15-2005 10:27 AM
