Old 10-13-2010, 11:00 PM   #1
StonecoreTx
StonecoreTx is on a distinguished road
Exclamation where does this go?!? asap
I'm changing a power steering line that had a pin-sized hole in it. In the process of putting everything back together but i had a line come out and i dont know where it goes. embarrassing but i cant find it in my tsrm or haynes. it's just says remove it for certain procedures but nowhere says where it is or where it goes to....?!?
where does the small line that is under the acordian hose go to?!?!
i cant find where it connects to.... please bump not much sun left. directly on the underside of the accordian there is a line fitting that has a small line that goes somewhere....WHERE? I assume it's for PCV but have no idea where it could go.
86.5 mk3 supra 7mgte r154
StonecoreTx is offline   Reply With Quote
Old 10-13-2010, 11:57 PM   #2
fantasma87
fantasma87's Avatar
hey look at the post that said " PSP LINE" theres a map of the streering sections , it might help . good luck . Q
ARMY STRONG !!
Old 10-14-2010, 12:01 AM   #3
StonecoreTx
I'm the one who put that diagram there for him lol.
it's not a powersteering line its a vac line that goes to the accordian, the one on the bottom. here is a pic. the one on directly on the underside of the accordian. under the thumb. has a nipple like a "L" shape 90 degree.
Old 10-14-2010, 01:37 AM   #4
StonecoreTx
found it. I hope this helps someone who has same problem.
it goes down to a vacuum valve on the top of the power steering pump. There are two lines connected to the power steering vsv, one goes to bottom side of accordion and the other goes to the metal bypass line that goes around front of motor and connects to the main vacuum distribution line under the front area of the plenum.
