#1 |
Supra Forum Moderator
12263-42010
at running. I see a constant dripping from the top of my cam cover to block breather hose. now im just curious, A constant dripping into this breather hose means I have a busted seal most likely? any diagnostic as to which seal would be most likely the culprit being the closest ? The hose is leaking from the top and believe the bottom. so a new hose is about to be ordered from champion. i think mag auto has it for 25 cents cheaper.. I can defiantly see it drip,drip. so that could more than likely account for the quart of oil loss per 2 weeks. any chance there is another type of hose I can just pick up at my local store than special ordering OEM? just about any straight type of breather hose? thanks for reading.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
MK3 supra Hose Techniques silicon hoses | Micahwc | Shops & Part Reviews | 8 | 12-09-2012 09:03 PM |
90 Degree hose job | Green7mgte | MKIII Supra | 1 | 06-09-2010 09:16 PM |
89 Breather hose | BlueTuner | MKIII Supra | 3 | 12-21-2009 04:27 AM |
Sm Vac Hose Under Accordian Hose | Chromemoly | MKIII Supra | 3 | 07-03-2009 01:19 AM |
Replacing Clutch reservoir Hose and fixing rock plate (plastic one) | Grandavi | MKIII Supra | 2 | 09-29-2008 04:49 AM |
