#1 |
About seven months ago I replaced the engine in my 1989 Toyota Supra Turbo, because the old engine had a blown head gasket. But now when I try to drive it on the street the car will not go over 30mph. The tach revs up but the car dosent speed up. Even changing the gears dose'nt help. It also smokes and idles rough or stalls out when the throttle is released. I dont have a clue as to what the problem could be. Do you have any suggestions?
walter ![]() |
#2 |
7M POWAH! ;)
at idle does it idle really rough and poke out heaps of black smoke?
when you are attempting to get faster than 30mph are you boosting? if you are try accelerating very gently thru the gears... try on flat road not hill if it does any of the above you have a boost leak if not let us know and we'll go from there ![]()
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
#3 |
even if he did have a boost leak he would still be able to go faster than 30mph..sounds like the rings are gone
MA70 widebody-1jz conversion with R154, HKS Type S intercooler, Tein HA coilovers, Apexi PowerFC, HKS step one Cams painted in AudiTT Blue |
Having some Troubles... | 87MGE | MKIII Supra | 4 | 05-03-2008 08:03 AM |
Knock Sensor Troubles!!!! | Draftinwitjr3815 | Non-Generation Specific Questions | 0 | 03-18-2008 10:16 PM |
engine troubles | yota_head | MKIII Supra | 4 | 02-21-2007 05:58 AM |
map ecu troubles | turbotaco | MKIII Supra | 2 | 01-03-2006 07:41 PM |
smog troubles | tonster | MKII Supra | 2 | 09-24-2005 10:21 PM |
