#11 | |
![]() Quote:
1986.5 MA70 7M-GE
1987 MA70 7M-GE |
#12 |
And the ge pipes had 2 vs 1 I think the ge intake would move more air then the gte pipe would with out a turbo forcing it in
#13 |
1986.5 MA70 7M-GE
1987 MA70 7M-GE |
#14 | |
![]() Quote:
so if you put the vain throttle body and plenum on the GTE it would get better air flow?
1986.5 MA70 7M-GE
1987 MA70 7M-GE |
#15 |
Supra Forum Moderator
not being negative but if your not into turbo's why did you buy so many supras. Nissan would abeen a good bet.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#16 |
ok the first one i got i got 2 yrs before i got my license. it took $900 to get her running. as soon as she fired i fell in love with the MK3 plus as soon as i saw her being towed into the drive way i loved the body style. which is why i wont go MKIV ( dont like how 93's up look ) and as iv said when i get the 1990 supra i want ill go balls to the wall. and rebuilding the 7M-GE and restoring the 87 i have will give me a good background of how to rebuild the engine and will help in the long run when i find the 90 supra with the 7M-GTE and the r154 trans. im just trying to stay away from the turbos cause of the added problems there could be. till i can understand the engine from the inside out. plus i only like the nissan skyline and thats a hard car to find in IL.
1986.5 MA70 7M-GE
1987 MA70 7M-GE |
#17 |
I think you need to go take a 7mgte for a test drive and you will forget all about the 7mge. I drove my friends 7mgte the other day and once you hit boost you will be addicted. If you are going to all the trouble of rebuilding a 7m why not make it a gte. A 7mgte stock will beat out a modified 7mge anyday. As long as you take care of the main wear items there is no way a turbo should not be as reliable as a na. I did the same thing with my na and it is still slow compared to a turbo.
The intake manifolds are different because the turbo forces air while the na sucks it in and I think it is the intake cam that is different. |
#18 | |
![]() Quote:
1986.5 MA70 7M-GE
1987 MA70 7M-GE |
#19 |
the heads are the same. the gaskets for intake and exhaust are the same for turbo or non. even a 5m head will fit the 7m (and thus the 6m), but i believe you have to change the pistons to match the head.
both cams (IN and EX) are different from what my interchange is showing me. from what ive seen around and heard, the ge cams on a gte give you about 15-30 hp gain, i guess it depends on if using new cams or used cams.
87 silver turbo targa, bone ass stock (for now) Last edited by bioskyline; 10-21-2010 at 07:34 PM. Reason: typo |
#20 | |
![]() Quote:
1986.5 MA70 7M-GE
1987 MA70 7M-GE |
Thread Tools | |
Display Modes | |
Blown Head Gasket? | BillW | MKIII Supra | 5 | 09-17-2010 02:06 AM |
Head skim requirement? | MA70-3.0GT | MKIII Supra | 11 | 12-15-2009 06:03 PM |
replacing the head and headgasket | skadaloz | MKIII Supra | 4 | 04-13-2009 11:54 PM |
Fel-Pro Head Gasket for Stock 1990 Turbo Engine | Benesesso | MKIII Supra | 5 | 03-10-2006 10:52 PM |
