Old 10-20-2010, 04:53 AM   #11
zby67
zby67's Avatar
zby67 is on a distinguished road
Originally Posted by btwilson86 View Post
Oh, okay. Those are the intake plenum's and the throttle body's.
The GE intake utilizes the Toyota ACIS system (info found here), whereas the GTE intake does not. Without this system, you will likely notice a decrease in power.
For example, 7M Cressidas are rated at about 15hp less than GE Supra's. Cressidas use an intake design more similar to the GTE than the GE.
so then vary vary bad idea to put that plenum of GTE on the GE ok thank you for the info! im trying to get the GE up as high as i can with out going turbo. im not one for turbo's.
1986.5 MA70 7M-GE
1987 MA70 7M-GE
zby67 is offline   Reply With Quote
Old 10-20-2010, 04:55 AM   #12
Sonyps307
And the ge pipes had 2 vs 1 I think the ge intake would move more air then the gte pipe would with out a turbo forcing it in
Old 10-20-2010, 05:03 AM   #13
zby67
zby67's Avatar
Here's a Cressida 7M
the cressida looks like shit lol!
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-20-2010, 05:07 AM   #14
zby67
zby67's Avatar
ok that makes sense. so with the stage 2 cams cold air intake and posably a 75mm tip and pipe with boring over by .20 or .40 how much hp gain would that get granted boring over costs alot and i plan on rebuilding the GE anyway.
so if you put the vain throttle body and plenum on the GTE it would get better air flow?
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-20-2010, 02:49 PM   #15
Green7mgte
Supra Forum Moderator
not being negative but if your not into turbo's why did you buy so many supras. Nissan would abeen a good bet.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 10-20-2010, 08:41 PM   #16
zby67
zby67's Avatar
ok the first one i got i got 2 yrs before i got my license. it took $900 to get her running. as soon as she fired i fell in love with the MK3 plus as soon as i saw her being towed into the drive way i loved the body style. which is why i wont go MKIV ( dont like how 93's up look ) and as iv said when i get the 1990 supra i want ill go balls to the wall. and rebuilding the 7M-GE and restoring the 87 i have will give me a good background of how to rebuild the engine and will help in the long run when i find the 90 supra with the 7M-GTE and the r154 trans. im just trying to stay away from the turbos cause of the added problems there could be. till i can understand the engine from the inside out. plus i only like the nissan skyline and thats a hard car to find in IL.
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-21-2010, 02:52 AM   #17
907mge
907mge's Avatar
I think you need to go take a 7mgte for a test drive and you will forget all about the 7mge. I drove my friends 7mgte the other day and once you hit boost you will be addicted. If you are going to all the trouble of rebuilding a 7m why not make it a gte. A 7mgte stock will beat out a modified 7mge anyday. As long as you take care of the main wear items there is no way a turbo should not be as reliable as a na. I did the same thing with my na and it is still slow compared to a turbo.
The intake manifolds are different because the turbo forces air while the na sucks it in and I think it is the intake cam that is different.
Old 10-21-2010, 04:16 PM   #18
zby67
zby67's Avatar
im sure it is lol. but with the mods iv picked with getting the GTE it would make the total 11,600 something with out the body. and as iv said ill wait to go out when i get the 1990 supra i want to get.
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-21-2010, 07:33 PM   #19
bioskyline
bioskyline is on a distinguished road
the heads are the same. the gaskets for intake and exhaust are the same for turbo or non. even a 5m head will fit the 7m (and thus the 6m), but i believe you have to change the pistons to match the head.
both cams (IN and EX) are different from what my interchange is showing me. from what ive seen around and heard, the ge cams on a gte give you about 15-30 hp gain, i guess it depends on if using new cams or used cams.
87 silver turbo targa, bone ass stock (for now)
bioskyline is offline   Reply With Quote
Old 11-08-2010, 06:13 AM   #20
zby67
zby67's Avatar
how can the heads be the same if the GE uses a distributor and the GTE has coil packs...? would there be any issues with the GE if you put coil packs on it instead of the distributor?
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Head skim requirement? MA70-3.0GT MKIII Supra 11 12-15-2009 06:03 PM
